« on: May 22, 2010, 07:48:59 am » |
Peter All, Instead of the Gigabyte EG45M-Ud2H the seller sold me the EG43M-S2H. He made a mistake. As i recall did you say to me that i should NOT get a energy saver MB? The EG43M-S2H is a energy saver. And what is wrong with those? Should i go try it? Grtz and nice weekend.. Gerard
« Reply #1 on: May 22, 2010, 08:19:13 am » |
Hi Gerard - No, I said that, but merely about processors. But I think Roy said something like you shouldn't *bother* about it. Maybe I'm wrong though.
What I do recall is that I told about the capacitors living longer when it's less hot in there. But I added to it that by the time they die you will have chosen another board again ...
All 'n all I think it can be beneficial to use less energy (not for the green thing but for SQ). But I am really not into those things. That is, not in the PC area. Others will be better at this, I'm sure !
What would be completely wrong is when the energy saving board would only accept energy saving processors.
« Reply #2 on: May 22, 2010, 08:26:36 am » |
Ah ok... Well than i will go ahead with this one... Thanx..
« Reply #3 on: May 22, 2010, 09:06:40 am » |
Maybe better wait for the response from others ! (but I can imagine you can't wait of course)
« Reply #4 on: May 22, 2010, 01:34:45 pm » |
Gerard,
Just DONT install any of the applications bundled with the mainboard and get the drivers (except maybe the network card) from the manufacturers.
The main difference between the two mainboards are the lack of the 2oz copper (the ultradurable) and a little slower video chipset (harder to play BD with it).
« Reply #5 on: May 22, 2010, 03:57:58 pm » |
Gerard,
Thank you for explaining Telstar. It's meant only for music so i will use VGA i think and noting special. And with the applications you mean the cd's that are in the box? The box shows pic's of Ultra Durable 3 and 2oz Copper btw. grtz
« Reply #6 on: May 22, 2010, 04:13:42 pm » |
And with the applications you mean the cd's that are in the box? Yes. The box shows pic's of Ultra Durable 3 and 2oz Copper btw. *scratches head* Anyway, no mobo will force those features on you. Knowing gigabyte biooses, you can disable all of them at hardware level (Indeed i did that on mine). Enjoy your new toy.
« Reply #7 on: May 22, 2010, 04:18:13 pm » |
And with the applications you mean the cd's that are in the box? Yes. The box shows pic's of Ultra Durable 3 and 2oz Copper btw. *scratches head* Anyway, no mobo will force those features on you. Knowing gigabyte biooses, you can disable all of them at hardware level (Indeed i did that on mine). Enjoy your new toy. Well to be honest the plastic were the MB is in shows those UD3 and 2oz pic's but that could be the wrong plastic from another MB. So you say i should keep this MB
« Reply #8 on: May 22, 2010, 04:54:25 pm » |
Gerard, Were does this mistake happen !? The GA-EG43M-S2H = Ultra Durable 2 motherboard design The GA-EG45M-Ud2H = Ultra Durable 3 motherboard design Hopes this solves the confusion, I gave you the right mobo discription, dont blame it on me. Its still a good mobo........... You decide ZeRoΩ
« Reply #9 on: May 22, 2010, 05:03:50 pm » |
Gerard, Were does this mistake happen !? The GA-EG43M-S2H = Ultra Durable 2 motherboard design The GA-EG45M-Ud2H = Ultra Durable 3 motherboard design Hopes this solves the confusion, I gave you the right mobo discription, dont blame it on me. Its still a good mobo........... You decide Roy really i do not blame you what so ever! The seller said he had the UD2H MB but when i was in the shop i gave me the S2H. He made a mistake he said afterwords to me. He does not have the UD2H but the S2H instead. Not that big of a problem, but this week i remember something Peter said so i want to be sure i make the right choise before i could not gave it back and buy someting else. And when you all say it´s a good one i sure will keep it.
« Reply #10 on: May 22, 2010, 05:06:43 pm » |
*nods*
« Reply #11 on: May 22, 2010, 05:23:13 pm » |
I predict it will be better as the MSI mobo you have there in now. Also i think that the winmate psu unit(s) will make more of a difference. Better on paper doesnt mean sh*t (poep), without testing or listening. You can try to locate the right mobo (if you can find it somewhere on the globe). How will mobo still effect sound quality with NOS1 connected ? Any earthmoving achievements on this Peter ? (galvanic seperation and psu) eitherway, you are NOS1 ready PS: are you already building ?
« Reply #12 on: May 22, 2010, 05:29:33 pm » |
Roy,
The HD’s and stuff came yesterday. The CPU cooller was to large so that has to go back. The Psu was delivered yesterday also. That was looking good. So only a splitter from one hd power supply to 5 i have to order on ebay.
For the rest everyting is there. ;-)
« Reply #13 on: May 22, 2010, 05:41:50 pm » |
Btw dont use the setup disc that comes with the mobo, it probably offers you all sorts of stuff you dont want or need, and they are not the latest drivers anyway.
Just download latest bios with @bios, it installs the new bios automaticly for you (but always check first) So you dont have to flash anymore. Download latest mobo and chipset drivers directly from gigabyte also optional is AHCI/RAID drivers. Gigabyte also has green-lan, so if lan port is not connected it disables itself.
Better come overhere and I will show you all. Its a fast PC so the install wont take that long, tweaking it takes a bit longer. Maybe do some psu and temp testing before you put the final build next to your amps.
Eindhoven Gekste!
« Reply #14 on: May 22, 2010, 05:45:44 pm » |
Einhoven Gekste!
I will let you now a soon as everything is there
