November 23, 2024, 12:03:19 pm *
Author Topic: Core Appointment and Multicore CPU-s  (Read 20088 times)
« Reply #15 on: May 16, 2010, 10:45:16 am »
Ah, that's different. Indeed I recall something like that could happen, but I never dedicated it to changing the volume. If I check it here now, all is right. Also I didn't notice it anymore for weeks, so I guess I have solved it.
Thanks.
« Reply #16 on: May 16, 2010, 10:54:43 am »
I can't set the 'Music Root' folder to the correct shared root folder in the NAS drive, so rather than using the Library, I simply use the 'Explorer' button.
This has been solved ... and IIRC longer ago than the latest version. Maybe you don't use the latest version (0.9y8-c) ? Or otherwise it will be in 0.9z.
Btw ... with "shared root folder", I take it that you mean a "share name" ? like \\St01\drive_c (st01)\WavTest\ in my case.
If so, notice that you can assign a drive letter to that ... See below at the mouse pointer, which says "Make network Connection". But I guess you knew that.
« Reply #17 on: May 19, 2010, 05:39:51 pm »
Before you throw away some money ...
Sorry Peter, I don't think I ever thanked you for the advice... I think I'll stick with my PCI AES-32 in that case - it has low enough latency to allow me to digitise 2-channel analogue at 24bit 176.4K/192K rates.
This will free up some funds to buy the two (I'm serious!) NOS1 DACs that I want from you. Does that put me absolutely top of the list? Happy
