I saw this nice looking DIY schematic 'Lightspeed attenuator' that uses optocouplers to attenuate the signal and my soldering iron started to get itchy, when I had the thought that maybe the digital attentuation inherent in XXHighEnd was as good/better. Any thoughts?
I have to admit that I am probably going to have to build one of these babies because the 'Legit' volume increments in XXHighEnd are too large for my system - in one step it goes from quite quiet to waking my children up, although I guess there is always soundproofing.
Any connectors or cable on the signal path will be worse than a lossless digital attenuation, period.
But I also agree with you that the steps in xxhe are too broad. That's the only way he could make it lossless, so it's a give or take.
the lightspeed requires that the source and amp are ALREADY matched in impedance, otherwise you'll need a buffer (i.e. more components along the way).
