April 06, 2025, 03:53:29 am *
Author Topic: best connection PC to DAC  (Read 6837 times)
wimck
« on: May 09, 2010, 12:47:23 pm »
In my situation there's no possibility to place my audiopc near the DAC so the distance is about 8 mtr (24 ft).
Now I am using a (too ?) long Canare coax cable.
Thinking about other, hopefully better,  solutions I found a RCA connector.
Then I can plugin the Hiface directly to the DAC so I don't need any coax.
But then I have to find the best possible USB to USB connection for 8 mtr.
One possibility is 2 USB active (?)  repeater cables from 5 Mtr.
Another way could be USB/UTP -> 8 mtr UTP6 -> UTP/USB.
please help me with suggestions, other ideas or whatever!!
(I know BNC connection would be better but I already have the RCA Hiface and my DAC doesn't have BNC)
Windows 7 Ultimate 64bit SP1 and XXHighEnd on SSD - music on spinning disk @SATAII - Athlon II dual core 2,9Ghz - Engine#4 -Adaptive Mode - Q1/2/3/4/5 = 1/0/0/0/0 - Buffer 1024 - MIxed Contiguous - SFS 20 - Playerprio Low - ThreadPrio Real Time - All Services Off
PC -> M2Tech EVO -> 10 m Canare digiflex Gold II -> TagMcLaren AV192 / 2x250MR -> VS Unifield3 -> my ears
« Reply #1 on: May 09, 2010, 01:28:39 pm »
Hi Wim,
I used 3 USB (extension, 1 euro) cables, and had 12 meters as a result. This just worked fine with the HiFace.
The only thing you have to watch for is dropouts, and the knowledge of *if* they are happening, this will be the result of too many resends because of the too poor (data !) connection.
Your 8 meters of coax certainly is not the best. At all ...
Page created in 0.011 seconds with 19 queries.
