November 23, 2024, 08:49:30 am *
Author Topic: iMON  (Read 8306 times)
BrianG
« on: April 21, 2010, 05:29:33 pm »
Hi all,
I've just built a new pc and put it into a case that came with iMON.  I loaded the Autohotkey app and entered the keyboard commands for xxhighend into iMON app and now I have remote control of xxhighend  Cool
 OK not totally robust and sometimes I have to reload the autohotkey script but if you have iMON then it's very easy to implement and works 95% of the time and I'm happy  Happy
Brian
« Reply #1 on: April 21, 2010, 06:09:14 pm »
Do you also have a display in there ? if so, I guess you will be receiving the weather forecast as well !
hehe
« Reply #2 on: April 21, 2010, 06:41:51 pm »
Brian,
Thanks - this is something that I'm planning to do this weekend with my two iMon-capable PCs, and it's good to know that it works... albeit only 95% of the time.
« Reply #3 on: April 23, 2010, 06:46:28 pm »
FIY Girder is 100% stable with IRTrans.
Ah, "progress" Wink
