November 23, 2024, 10:04:48 am *
Author Topic: Small Icons  (Read 8907 times)
glynnw
« on: April 19, 2010, 07:46:48 pm »
At some time after I started using 09-y8, all the album covers that appear in the middle section when I select an item from library became very small.  Version 09-y7 still shows them larger.  I completely reinstalled the latest 09-y8 version and still have the small icons.  I also have XXHighend on another computer, which does not display this problem, so I must have done something to my main music computer to create this problem.  Attached is a screen shot.  Any ideas?  I should add that I do not use the gallery function.  All my albums are listed by artist when I push the library button, I click on the artist and all that artist's albums appear in the middle pane.  Then I double click on the album cover and hit play.  Then I enjoy.
« Reply #1 on: April 19, 2010, 08:40:52 pm »
Just move the slider, see pic Wink
glynnw
« Reply #2 on: April 20, 2010, 01:37:15 am »
So sweet!  Thank you very much.
BrianG
« Reply #3 on: April 20, 2010, 05:38:49 pm »
Chaps,
May I use your screenshot to ask another question please?
If you look at the track time/duration bar, this goes to the end of the "box" for any size box you choose.  Is this correct or should it have a set length?
Brian
« Reply #4 on: April 20, 2010, 07:11:55 pm »
Hey Brian,
If you mean whether the slider should grow with the width of the form (screen), yes, it should ...
But is it that what you mean ? it is not fully clear to me.
BrianG
« Reply #5 on: April 21, 2010, 05:21:07 pm »
yes Peter, it grows but doesn't seem to stop growing just runs to the rhs of the box, I'll give it a closer look and see what happens when taken to full screen size.  I was expecting the line to end at some predetermined application box size dntknw
« Reply #6 on: April 21, 2010, 08:11:55 pm »
I recognize this problem, its about screen-size settings.
Because I use temporary a 2nd monitor with different resolution, I have this too.
The slider goes beyond the form, even on full screen.
Adjust the slider on screen size settings (resolution or width) in your code, Peter.
Houdoe
