November 23, 2024, 05:59:04 am *
Author Topic: Issue with AutoHotkey  (Read 5746 times)
jarek
« on: April 15, 2010, 02:14:21 pm »
I have strange problems with XXHighEnd working with AutoHotkey in attendent mode (did not test unattendent yet). Simply, commands sent to XXHighEnd cause only moving focus to a function button, and one need to press ENTER afterwards. For example, ALT-S highlites the STOP button, but does not executes STOP, I have to press <Enter> afterwards. The same other shortcuts. The problem is that from time to time it works fine, but more and more often it only highlights buttons by setting focus to them.
« Reply #1 on: April 15, 2010, 03:40:44 pm »
Jarek, I can only say that I am experiencing the same ... sometimes.
If I only knew how to copy this behaviour at will, I could work on it and solve it. So, this sure is an issue, but I think you are the first to really mention it. I am sure though that more people must have problems with this;
Maybe comeone can tell when this happens ? Hence, what to do so it *will* happen ?
Thanks !
« Reply #2 on: April 15, 2010, 04:44:46 pm »
FYI I do NOT have such problems with Girder Happy
