April 17, 2025, 11:42:19 am *
Author Topic: 09-y8 - Track loading is very slow  (Read 8778 times)
stoneman
« on: April 08, 2010, 09:23:56 am »
I installed the latest version and I have to say there has been a big step-change for the better in sound quality.  Well done!
That said, it is taking ages to load tracks - e.g. if I hit NT it takes about as long as it would to stand up and change a CD, any tips on how to fix this please?
regards
Andy
« Reply #1 on: April 08, 2010, 09:35:50 am »
Hi Andy,
How many tracks (and how many minutes on average) will there be after this Next track (in the Playlist Area) ?
And is this Attended or Unattended ?
stoneman
« Reply #2 on: April 08, 2010, 10:21:18 am »
Hi Peter
"Crime of the Century by Supertramp"  (showing my age!) 8 tracks approx 5 mins each "Unattended" without tick - taking about 20 seconds to play from start and to switch track
I tried "Unattended" with tick - woudnt play at all and I had to close XX and clear lots of error messages
regards
Andy
« Reply #3 on: April 08, 2010, 10:30:59 am »
Andy, this implies that one track loads in 20 seconds in your case. This is not workable (should be 1 second or so) !!
I bet the Unattended (with tick as you say) just works, but you aren't patient enough to wait for 8 x 20 seconds (or whatever Crime of The Century contains).
So ... whatever it is, you have things ... uhm ... very wrong ?
For a better persepctive you may tell may what you play (FLAC etc.) and how (Double etc.) in this "20 second case".
stoneman
« Reply #4 on: April 08, 2010, 11:57:44 am »
Hi Peter
FLAC files with no setup changes - simply replaced all of the files I had before with the new download.  Yes it takes 20s for one track to start.
System is Core2 T5500 1.66 GHz, 2Gb RAM, 256Gb, SSD, W7 Lynx L22 card.  FLAC stored on the SSD in own folder on C:, XX installed in its own folder on C: I only used this machine for music, although its connected to my home network.
Settings are:
KS: Lynx L22 01+02 >> #wave1
#4 Engine
KS Mode: Normal
Device Buffer size: 32
No Appointment
Prios: Nothing and Nothing
DAC is 24 bits at 192
> 16 bits = "32"
Allow Format = "Tick"
Crack detect = " "
Quality = no ticks
No upsampling
V=0 (top)
Q=15 (middle?)
regards
Andy
Lynx buffer
« Reply #5 on: April 08, 2010, 01:07:54 pm »
Are you able to temporarily create a setup that excludes your SSD ? (the OS is allowed to be on it allright !).
Something must be wrong ...
Page created in 9.549 seconds with 19 queries.
