OMG OMG,
Already applied the Juli@ with a direct spdif coax-output instead of Toslink, but did not really had a change to listen.
I only checked the new coax output with a cheepo analog cable with those ugly connectors, to test if it worked.
It did.....
And now it does........
Just put a homemade coaxial Digital interlink between the juli@ and my DAC.
Its a Belden 1694a coax cable with those Eichmann Silverbullits.
I prefer I2S over anything, thanks to Peter i had that change to experience.
But for the time being, I am very happy this tweak.
The hights became more crystal and very very sparkling, but remain smooth.
Soundstage is a little wider, but defenitly more into the front and back
Bass is deeper and faster, into the mids and mids more into the hights, it makes it more complete.
No more "gaps" in the soundstage.
If you can handle a solder, just put a decent BNC or 75ohm RCA connection on *her*.
And help the lady off her cold.
I give this tweak an 8+, sonicly much better.
AuDioDiDakt
PS: Its also possible to completly lift the spdif side of Hanrun transformer, and connect your spdif directly on the transformer.
without making connection to the lines on the PCB.
So disconnect all other output lines after the Hanrun transformer.
As discribed on audioasylum.
Next some Caps ?!
