April 05, 2025, 05:39:11 am *
Author Topic: Windows 7 GodMode  (Read 10789 times)
BrianG
« on: March 31, 2010, 09:35:32 pm »
I'm just about to build a new W7 PC with a SSD drive and whilst looking at the OCZ drive forum for info on how to get the best etc. from SSD I found out about this:
By creating a new folder in Windows 7 and renaming it with a certain text string at the end, users are able to have a single place to do everything from changing the look of the mouse pointer to making a new hard-drive partition.
The trick is also said to work in Windows Vista, although some are warning that although it works fine in 32-bit versions of Vista, it can cause 64-bit versions of that operating system to crash.
To enter "GodMode," one need only create a new folder and then rename the folder to the following:
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
Once that is done, the folder's icon will change to resemble a control panel and will contain dozens of control options.
Has anyone tried this?  Grin
Brian
Jack
« Reply #1 on: March 31, 2010, 09:46:28 pm »
Is this one of those tweaks that only works on April 1st up until noon?
« Reply #2 on: March 31, 2010, 09:49:35 pm »
 Wink
Marcin_gps
« Reply #3 on: March 31, 2010, 10:37:56 pm »
No, it works fine, but there is no need to name the folder GodMode, you can type whatever you want followed by .{ED7BA470-8E54-465E-825C-99712043E01C}
« Reply #4 on: April 01, 2010, 08:59:21 am »
Should work for Vista as well.
stoneman
« Reply #5 on: April 08, 2010, 09:34:34 am »
Works in W7 x64 too!
Page created in 0.017 seconds with 19 queries.
