November 23, 2024, 06:18:37 am *
Author Topic: 'No tracks given' error  (Read 26048 times)
Gianduja
« Reply #15 on: April 01, 2010, 09:13:10 pm »
.... but must be about something I just did wrong for 16/44.1 files (that is, I think it only happens with those). Here this just works, and I guess with most this works, unless by now everybody is upsampling where this (as far as I can judge) doesn't happen.
So ... I just have to repair something somewhere, which is not an easy job as long as I can't mimic it. That's all !
Ok ?
Hello, with the versions later than "y6" I have the "No tracks given" error always, both with upsampling and without, I tried with wav, mp3, flac.... all the same:-(
The y6 worked, but it often crashed and was slow.. I use Win Seven32bit. Thanks
« Reply #16 on: April 01, 2010, 10:32:20 pm »
Hmm ... This makes it even more strange.
In any case, thank you very much for sharing !
LydMekk
« Reply #17 on: April 02, 2010, 03:48:36 am »
Same problem here too. Tried y8 and y8c, no track given.
Went back to y4, works fine.
« Reply #18 on: April 02, 2010, 09:10:46 am »
Ok. Could any of you please unzip the below XXEngine3.exe over your current XX 0.9y-8c install, try it with this one, and post the XX and X3 logfile of it.
If you in the mean time hear sound, you can tell me. Happy
Preferrably try this with a WAV file (no big deal, but things will be more clear for me then).
Thanks a lot,
* XXEngine3-09-y8c-06.zip (110.75 KB - downloaded 560 times.)
DannyD
« Reply #19 on: April 02, 2010, 04:24:11 pm »
I just want to make sure it registered with you that I was having this "No Track given" error with versions newer than y6 when I was using the spdif port on my motherboard, but as soon as I started using my new HiFace, the problem went away.  I think this may be a worthwhile clue for you in debugging.
Dan
« Reply #20 on: April 02, 2010, 06:55:52 pm »
Thank you Dan. But thus far I still don't get this. I hope that the others (or anyone) will respond to my last post.
« Reply #21 on: April 02, 2010, 09:31:43 pm »
I just went from 9y-6 (which plays eng 3 "perfectly") to 9y-8 & 9y-8c and I'm getting the "No Track Given" window and then a "No Track Found" window, and no sound. Both with eng 3 & eng 4 using 9Y-8c
« Reply #22 on: April 02, 2010, 10:55:43 pm »
Welp... finally got 9y-8c to work.  But I don't really know how.  I reinstalled it a couple of times...  I kept playing and stopping it... went back and forth between eng 3 and eng 4... then magically eng 3 started making music.. now I'm trying to find settings for eng 4 special to work correctly, but I'm not finding it with the FF800 settings buffer sizes and XXHE settings buffer sizes.  I just now tried Adaptive mode, and it works with 128 buffer for FF800 and 128 buffer for XXHE.
« Reply #23 on: April 03, 2010, 04:48:05 pm »
Thanks to Christian (love) the issue was found. For now, solve it like this :
Those who are bothered by this, will have shown nothing in the KS Mode combobox (Settings Area). These people also will be using Engine#3 ...
Hopefully you can select a KS: device (temporarily) because that allows you to make a choice for KS Mode. So, something should be shown there, or otherwise ... "no track given".
Btw, for Device Buffer Size the same applies. Just choose something there.
After something shows in KS Mode and Device Buffer Size, you can reselect your Engine#3 device, and sound will be there.
Christian, on behalf of many, thanks for the (super fast) help !
Matt E
« Reply #24 on: April 14, 2010, 01:10:41 pm »
Sweet! Thanks Christian & Peter
Page created in 0.188 seconds with 19 queries.
