November 23, 2024, 08:30:20 pm *
Author Topic: 09-y8 Special Mode, Pop when playback starts  (Read 4860 times)
« on: March 22, 2010, 12:39:23 pm »
Reading that most people prefer Special Mode to Adaptive mode, I decided to attempt the same too. The problem I face is whenever I start playing a track I get  loud pop & then it plays normally. I tried several Q1 settings but in each case the loud pop is present. Any suggestions what could be causing it?
« Reply #1 on: March 22, 2010, 10:00:24 pm »
Hey Arvind,
I have looked in the program, but there is no difference between Special Mode and Adaptive Mode for the first played samples (notice though that in earlier versions there sure *was* a difference). So, the only thing I can imagine that your soundcard/DAC somehow has problems with the first sequence of samples ... On that matter, try Special Mode with a higher Device Buffer setting, so Q1 will show something like a few hundred samples (or a 1000 or so). If it then is still the same (while at Adaptive Mode you really don't have a problem with that), well, then I don't know !
