November 23, 2024, 07:59:17 pm *
Author Topic: Further solved issues in 0.9y-8c  (Read 5709 times)
« on: March 13, 2010, 08:40:12 pm »
I have added an XXHighEnd-09-y8c (containing an XXHighEnd.exe and XXEngine3.exe only) at the bottom of the 0.9y-8 version (XXHighEnd Model 0.9y-8 (Stable KS version)).
The solved issues are (these were contained in the earlier anounced 0.9y-8b, now contained in 0.9y-8c as well) :
- When (at Unattended) no OSD Time and OSD Text was asked for, the Wallpaper (when asked for) only appeared at the second track.
- Wen (at Unattended) playback automatically stopped because the Playlist Area finished playing, XXHighEnd was brought up, but the Wallpaper (when asked for in the first place) stayed.
The following adjustments are additionally contained in 0.9y-8c :
- Rips from dBPowerAmp end with tag data; when such a track was started not in the beginning, that data would express as noise of a second or so. This is now solved.
- It was found that at changing the Digital Volume old code was used when Arc Prediction was not used, or DAC Needs was set to "24 bits only". At the ultra low latency settings this may have incurred for an "out of sync" and noise as a result. Notice that the adjustments concerned are theoretical soltutions to this, and it could not be tested.
- After Unattended Playback and the auto-bringup of XXHighEnd, (when asked for in the first place) the Coverart Wallpaper stayed. This is now solved.
- The X3PB log file now shows the set Device Buffer Size and the used Q1 value (in samples for KS Special Mode).
- It was found that the digital Volume Change, used at Attended Playback, used old (slow) code. This has now been changed into the "unattended code".
- It is now possible to use the Digital Volume slider for changing the volume during playback. Notice that this doesn't work for Attended only, but also for Unattended. To let the latter work, bring up XXHighEnd (Alt-X with AutoHotkey properly installed) and just change the slider position.
« Reply #1 on: March 13, 2010, 09:38:31 pm »
Important :
For 45 minutes or so (before the time of this post) a 0.9y-8c version has been there that needed clicking Play twice (in certain circumstances) or otherwise nothing would happen. If you experience this, please download 0.9y-8c again.
Most sorry for the inconvenience.
« Reply #2 on: March 14, 2010, 02:13:13 pm »
 tongue2 tongue2 tongue2
Page created in 0.081 seconds with 19 queries.
