November 23, 2024, 05:51:28 pm *
Pages: 1 2 [3] 4  All
Author Topic: Hiface Impressions  (Read 66869 times)
« Reply #30 on: April 09, 2010, 12:03:40 pm »
I found a PCI to USB2 card with NEC chip here for 10 Euro: http://www.vedt.nl/cgi-bin/FS?longshine&Longshine+is+VET+met+DT&Top&shop&Content
And guess what? It works!
So USB from AMD-chipset: No
PCIe to USB3 (Nec) : No
PCI to USB2 (Via) : Yes but distorted.
PCI to USB2 (Nec) : YES!
And it really sounds better then anything before.
With the hiFace from the laptop it did not really sound convincing in the end.
From AMD-htpc there is a huge improvement.
The htpc is W7/tweaked and seperate USBcontroller, laptop is Vista, not tweeked...
« Reply #31 on: April 09, 2010, 12:17:57 pm »
Keep it up GerardA and you might just convince my to give up my laptop....something Peter has been unsuccessful at getting me to do!
« Reply #32 on: April 09, 2010, 12:28:58 pm »
Now, if you could only convince your spouse, hehe Wink
Marcin_gps
« Reply #33 on: April 09, 2010, 06:37:28 pm »
GerardA,
I told you, that a good quality USB controller matters, especially that your interface uses 5V from USB, no magic.
« Reply #34 on: April 09, 2010, 09:40:20 pm »
I told you
Yes! And what about a PCIe to PCI adapter?
You already tried it?
Makes a seperate Power supply for the PCI card possible.. Wink Wink
Marcin_gps
« Reply #35 on: April 10, 2010, 10:36:01 am »
No, I haven't, but now thanks to you it's on my shortlist :D
« Reply #36 on: April 18, 2010, 02:02:12 pm »
Anyone here had a chance to listen to a JKeny modded Hiface? How's it sound? Any replies greatly appreciated.
DannyD
« Reply #37 on: April 18, 2010, 03:45:39 pm »
I've had one on order for a few weeks.  Hopefully not too much longer.  I'll let you know.  I'm enjoying a stock HiFace now and in many ways prefer it to my Lynx AES16 card.
« Reply #38 on: April 18, 2010, 11:39:33 pm »
Thanks Danny. Look forward to hearing your impressions of the mod.
« Reply #39 on: May 14, 2010, 02:52:04 pm »
Well, there's always the next "best thing". Check this out:
http://www.computeraudiophile.com/content/Halide-Design-Bridge-Review
« Reply #40 on: May 14, 2010, 03:01:32 pm »
Excuse me ? USD 450 and only 24/96 ? What would be better about it than your HiFace ?
« Reply #41 on: May 14, 2010, 03:39:12 pm »
True, but Chris's impression is that the sound beats the Hiface.
Marcin_gps
« Reply #42 on: May 14, 2010, 04:23:19 pm »
Stock Hiface. That kind of devices (powered from USB) will play differently with each PC. (PSU, motherboard power section, cpu, overall performance, etc not to mention OS and software...)  I think Chris overlooked this factor, which has great impact on SQ, even when it comes to S/PDIF only.
« Reply #43 on: May 14, 2010, 04:29:21 pm »
Without degrading anything of the reviews or expressions otherwise, I never understand them (hence which makes it worthless to me).
The last thing you will hear me say is that they are wrong or off per definition, but all there is in another context. It is not wrong, and probably consistent within itself. But different from, say, here.
If it is better, well, it just is. But especially for a device like this I would like to know why.
PS: Like Marcin just gave an example.
Marcin_gps
« Reply #44 on: May 14, 2010, 10:10:34 pm »
I can tell that there is a huge difference between device A connected to system X and device A connected to the same system X, but underclocked, undervolted and highly optimized. I didn't believe until I heard myself and got a jaw drop.  teasing
My system is now running at four cores @ 1GHz and 0.825V (default is three cores, 1.325V), 2x2GB DDR3 (1.5V, CL5), no fans (even in a PSU), SSD for win 2008R2 (leightweight 64bit "server edition" of Windows 7), 2x1.5TB eco drives for data, no optical drive. That plus XXHighEnd and some minor os optims is a good way to start computer playback. It's not enough to buy a fancy DAC or soundcard and forget about everything else. Good power equals ~50% of overall SQ (IMHO).
Page created in 0.182 seconds with 19 queries.
