April 05, 2025, 06:53:31 am *
Pages: 1 2 [3]  All
Author Topic: 09-y8  (Read 42845 times)
« Reply #30 on: April 22, 2010, 09:38:29 pm »
Stupid reason : You got used to the other sound now, and better hear the difference with something you liked better in the first place ?
Also, very often a change (no matter which) sounds better. But later you hear the anomalies.
Lastly a more normal reason : the power saving settings of your new install changed, hence the performance of the PC. Those stupid settings do more than we want ...
Marcin_gps
« Reply #31 on: April 23, 2010, 01:19:36 pm »
Yeah, regardless of mode (special or adaptive), the sound is sharper, more edgy ;/ Before reinstallation I could sleep while listening to music, now my ears hurt - this is the best description of what I'm experiencing right now.
What power settings are you talking about? My power plan is set to high performance.
« Reply #32 on: April 23, 2010, 03:24:31 pm »
That doesn't say much, because in there you can tweak each setting to as low as you want (meaning : you could have done that with the before install). But keep in mind it is only a suggestion.
If the OS itself is not the same as before (what about a beta vs RTM eh ?), well, then you're quite lost.
What you also could do is perform the install again, but sit back and think what you could have done differently the very first time.
Tough one, and certainly not nice. Sounds similar to my moving from Vista to W7, but apart from some priority changes in the internals of the program the new KS solved all for me. Maybe it wasn't even W7, but just "the install" in my particular case. I mean, I was about the only one complaining at the time.
I hope you can find it ...
Marcin_gps
« Reply #33 on: April 24, 2010, 05:54:21 pm »
I've found the culprit, very odd though. It turns out that I had to go back to plain y08, play a song with my settings of choice (adaptive, Q1=1) and then upgrade to 8c. Going to 8c right away results in edgy sound, listening to it makes me sick (or fatigue, to be perfectly clear). Fortunatelly, my ears are happy again Happy
« Reply #34 on: April 25, 2010, 10:14:12 am »
I believe you because I believe in everything. swoon
But how can this be ??
On the other hand, if you would skip the 0.9y-8 base, what base would you have ? Nothing isn't possible, so that should have been some other version (?). And *that* is not allowed ...
Marcin_gps
« Reply #35 on: April 28, 2010, 01:53:04 pm »
I believe that there is no one clear recipe for good sound from PC. Everything affects everything - hardware, software, drivers etc It's best to have dedicated audio server just for playback, with absolutely no additional software and drivers (especially those for GPU and network adapter).
Peter, tell me, please, for adaprive mode, if I set buffer size to 64 samples and get sound without distortions, does it mean that my card supports latency at 64 samples? It wasn't possible when I used drivers from M-Audio, but now that I switched to Ploytec, it seems that I can get a clear sound even at 64 samples, but I get the feeling that it's somehow louder (probably due to increased detail).
« Reply #36 on: April 28, 2010, 02:00:22 pm »
Assuming Q1 = 1, yes. Happy
Keep in mind : this is hard-detected by means of the buffer errors (see X3PB log file). So, you may have buffer errors at switching Coverart or other demanding stuff, but not throughout. If you have zero of them, go and try 48. yes
Pages: 1 2 [3]  All
