November 23, 2024, 07:15:47 pm *
Pages: 1 2 3 [4]  All
Author Topic: 09-y8 wallpaper problem  (Read 44569 times)
« Reply #45 on: June 06, 2010, 03:26:59 pm »
OK done that and there is no difference still the same problem.
If I am running in unattended and I call up the xxhighend GUI with altx I can then change volume using hotkeys.
P
« Reply #46 on: June 06, 2010, 03:40:24 pm »
Grrr ...
Ok, now I want to know whether - and how much those commands are being processed by XXHighEnd ...
Be sure to have a TemporaryData folder under your current XX folder (it isn't created automatically in this version per a bug).
Set the Loggin On.
Start Playback as always (Unattended), and use Alt-U one time.
Wait one minute or so.
Don't touch anything further, but get the XX and X3 log files (X3PB is not necessary), and post them.
Notice that in order to do this conveniently you should have an Explorer instance running, so you can grab the files.
After you caught the files, you can stop playback.
If you want of course. Happy
Sorry AGAIN for the troubles ...
« Reply #47 on: June 06, 2010, 04:43:02 pm »
here they are
* X3-20100606-153658.log (7.4 KB - downloaded 489 times.)
* XX-20100606-153525.log (18.74 KB - downloaded 504 times.)
* XX-20100606-153722.log (0.71 KB - downloaded 515 times.)
« Reply #48 on: June 06, 2010, 05:10:23 pm »
Thanks Paul.
If you look in the second XX file, you see an access violation to a path\file.
If you can find the file, you don't have the rights to change attributes of it. Somehow.
If you can't find the file, you have no rights to create files in that folder. But I can't imagine that ...
There's the actual impossible option that you can't find the file because it is hidden, but then I don't know what went wrong. So all 'n all it should be about "no change attributes rights". Well, maybe you heard of that ... swoon
ANYWAY, this is the cause !
« Reply #49 on: June 06, 2010, 09:30:03 pm »
interesting and I cannot see anything immediately wrong but I will have a look at it and let you know how i get on
Thanks
