November 24, 2024, 04:06:46 am *
Author Topic: Weird CPU-usage behavior  (Read 21779 times)
DannyD
« Reply #15 on: March 06, 2010, 04:49:40 pm »
I'm running in Attended mode.  Here are the logs from my last run where I played two and a half songs.  The CPU-usage on the first song fluctuated in 2-second intervals between 0 and 14%, and on the second and third song between 1 and 50%.  My buffer size is set to 64 with Q1=1 and using QAP.
* X3-20100306-071311.log (17.71 KB - downloaded 1026 times.)
* X3PB-20100306-071311.log (2.91 KB - downloaded 1506 times.)
* XX-20100306-071126.log (39.92 KB - downloaded 1459 times.)
« Reply #16 on: March 06, 2010, 08:26:54 pm »
Found it !!
This happens with Attended when the Wallpaper is set not to show !
So for now, just set that to show and it is solved.
But I will solve it for real of course.
heat
DannyD
« Reply #17 on: March 06, 2010, 08:48:58 pm »
Unfortunately, turning on "Show as Wallpaper" hasn't solved the problem.  I'm seeing the exact same behavior.
« Reply #18 on: March 06, 2010, 11:46:49 pm »
And a Wallpaper ?
DannyD
« Reply #19 on: March 07, 2010, 12:30:06 am »
I had to show "At Attended" too.  Now I 'm getting the same cpu-usage in subsequent songs as I do in song-one. Are the 2-second intervals between 0% and 16% what I should expect?  Should I use a bigger buffer to bring cpu-usage down? I am seeing 0-10 buffer errors per minute, but I rarely hear any ticks or pops.  If I make the buffer larger I start to lose some of the sonic magic.
By the way, thanks very much for your terrific service!!!
« Reply #20 on: March 07, 2010, 12:37:33 am »
Ah, great Danny. I was disappointed already. But good, not anymore.
Now we know this, at this moment I don't trust what I see from the cpu at all. The point is, the interval is exactly the same for both the 50% case as the 16% (or whatever) case. Even the interval in the first core is so.
But hey, it sounds good here ! hahaha
I gues when I found this one (the bug), I/we will know more.
DannyD
« Reply #21 on: March 07, 2010, 12:50:32 am »
Okay, Peter.  In the meantime, I'll sit back and listen to some music.
