November 24, 2024, 02:33:15 am *
Author Topic: CPU performance  (Read 23428 times)
listening
« on: March 03, 2010, 08:52:30 pm »
If I'm using an ATOM-330 based PC running XX there are sometimes pops with low buffer and low Q1 settings. Looking at the task manager I can see a good balanced CPU load over the 2 cores and the 2 hyperthreading cores (every core appr. 5% load). If the pop happens the load of one core increases to 100% load for a short time (as shows Engine3 in process explorer). What could be the reason?
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: March 04, 2010, 10:15:25 am »
Hey Georg - I will try to explain it :
The peaks you see are very normal, and are needed to process a next track, or part of it. Notice this is related to your "Split File size" setting (Settings Area). But since you're using an Atom, things may become difficult ...
Generally we can say, the higher the Split File size setting, the less of those peaks you will see, but the more intense (and/or longer lasting) they will be. So, what you'd stribe for is "once per track". Now, there are two reasons you won't be able to achieve that :
1. Too few memory;
2. Too intense to avoid the plop (etc.).
#1 can theoretically be overcome, but it implies #2 to be worse, so, the solution is to decrease the Split File size setting, no matter you should stribe for the large setting; it just won't go for you.
Note : I am thinking of applying "the peaks" somewhat differently, which is related to them now being spread over two cores, and thus interfering with playback. The net result of stearing that to core one, however, may not be better. This is because now (then) the processing will take much longer, that preventing other tasks not being able to continue (the xx other OS tasks still around), and the result may be worse. I must say though that I don't know the effects at this moment, just because I never tried.
All 'n all "we" are working towards two contradictions :
a. Achieving the lowest latency possible because of better sound quality (never mind how, but it is so), that requireing more processing capacity;
b. Using small boards (small cabinets) with so far less processing capacity (like an Atom just has (far) less processing capacity.
Let me add to this that XXHighEnd goes over the top from all directions, because it's not only playing from memory, that requiering the processing in peaks, but it's also using the ultra low latency (unheard of really), which is a contradiction within itself;
For a normal processor this goes, but for an underpowered processor this is too much asking.
But I'll try to change some things in a next version, in order to let it go in all cases.
In the mean time, play with your Core Appointment Schemes which *really* matter in this case, set the Thread Priority to Real Time and the Player Priority to Low, and when you have found the "least disturbing" setting, lower your Split File size to the point you hear no pops at all.
And, assuming you are using KS Adaptive Mode (which is really the advise at this moment), you may observe the X3PB log file for the Buffer Errors decreasing, while you changed settings. Notice that they may emerge just at those peaks you see.
Lastly, notice that buffer errors around a peak because of loading a track part are different from those at loading a track, *unless* you shut off the Wallpaper and OSD Text, then they can be interpreted as the same (refreshing the Wallpaper is one of the most heavy tasks, and that only happens at track boundaries (a few seconds before the end of a track), or when you change the digital volume.
HTH !
« Reply #2 on: March 04, 2010, 04:19:14 pm »
Ok, I tried, but what I wanted to do is already in there : Core Appointment Scheme 1. This moves the load activity to the first Core and playing keeps on happening on the second Core.
But does that help you ?
« Reply #3 on: March 04, 2010, 06:58:44 pm »
I have been playing with this a bit myself now, but even if it avoids the pops etc., it is not said you are going to like it. Because remember, while all the "other" activities now (Scheme-1) nicely go to the first core, it takes relatively ages to preproces stuff (you just cut out 50% of the available capacity). So, YMMV !
listening
« Reply #4 on: March 05, 2010, 08:45:05 pm »
I found a solution in the mean time - I need speed, speed, speed. I tried all combinations but always had similar problems. I found the help in some overclocking forums and that's what I did:
  • Disable the two hyperthreading cores via BIOS
  • Overclock the ATOM 330 to 2.1 GHz. That works fine if there is only XXHighend playing. I determined core cpu temperatures of about 45 °C, 85°C is specified by Intel
  • Spend some extra PCI latency for the Juli@ via BIOS
  • Use Scheme-1
  • Set split memory to 12 MBytes
Until now I'm happy with double sampling / arc prediction for 16/44.1 and 24/96. Thanks a lot for your experiments.
 scratching I forgot to write that the system is right now very sensitive of electrical interferences from the power side.
Georg
-> SMSL SU-8 ES9038
« Reply #5 on: March 05, 2010, 10:55:58 pm »
Just one question :
Was this the advice ("That works fine ...") or your observation ?
Just for my understandings. Thanks,
listening
« Reply #6 on: March 06, 2010, 08:53:09 am »
I got two of ATOM-330 based PC's. I modified both as written above and found a problem with the second one. I had to decrease the CPU clock to 2 GHz because the installed RAM was too slow unhappy Apart from that the systems are working stable.
Georg
-> SMSL SU-8 ES9038
listening
« Reply #7 on: March 06, 2010, 03:20:46 pm »
There is a little strange behaviour: Sometimes the first title from a playlist plays flawless but the second title (and the following titles) are interrupted by memory load frequently. If stopping the replay of the second title and starting the second title again, all works fine - until the next title of the playlist. What could be the reason?
Georg
-> SMSL SU-8 ES9038
« Reply #8 on: March 06, 2010, 03:31:12 pm »
You are not using Anti Imaging, right ?
And is this with Attended ? (just the answer is sufficient, you don't need to try the other mode)
listening
« Reply #9 on: March 06, 2010, 03:49:50 pm »
Yes, it's attended but I'm using double with arc prediction.
Georg
-> SMSL SU-8 ES9038
« Reply #10 on: March 06, 2010, 04:27:49 pm »
Looks similar to this one I think : Weird CPU-usage behavior.
But what do you exactly see with this "memory load" ? (I could also ask what you mean by this).
Can't you post a screencopy of the graph of it ?
listening
« Reply #11 on: March 06, 2010, 05:15:30 pm »
I made two screenshots: The first shows the right behavior the second the interrupted playing. There is an additional constant load in the second cpu core. The music playing is interrupted when the performance peak arises in the first cpu core. I can hear another characteristic symptom: There is a little relay build in the Beresford DAC which disrupts the output if it is searching for the correct sampling frequency. It is clicking exactly at that time - he SPDIF output ist disturbed.
-> SMSL SU-8 ES9038
« Reply #12 on: March 06, 2010, 08:28:48 pm »
I found the problem from the other topic (Weird CPU-usage behavior). Can that be your case too ? (Attended and not show Wallpaper)
It doesn't look like it, but who knows.
Do you run Attendedly ? (sorry if you already told it)
listening
« Reply #13 on: March 07, 2010, 12:02:43 pm »
I followed the tread with DannyD and my problem is solved too with this workaround  thankyou
Georg
-> SMSL SU-8 ES9038
« Reply #14 on: March 07, 2010, 01:03:48 pm »
Aha ! That's more than what I have hoped for. Especially since your graph looks completely different from mine (and what I expect from Danny's) -> Spikes.
Anyway, it is solved for the next version.
Just one additional question : how do you manage to have such a low memory useage ? I mean, XXHighEnd may just manage to use that few, but where's your OS necessities ? or is the Atom enforcing this ?
PS: For me Scheme-1 doesn't work well. Not with a 100MB or so split size. The boundaries are just audible then. So my theories may not match reality. And to keep in mind : you may reconsider your settings now the cpu is more normal.
Page created in 0.16 seconds with 19 queries.
