November 23, 2024, 07:48:29 pm *
Author Topic: No Wallpaper at first track in 09y_7  (Read 24806 times)
« Reply #15 on: March 09, 2010, 08:49:24 pm »
Is it true for you both that you didn't ask for OSD Time and Text ?
I'm using the OSD text. I did a test this afternoon to untick this option. Still no wallpaper in the first track after a play command.
Please delete the old wallpaper after a clear command......?!
« Reply #16 on: March 09, 2010, 09:36:03 pm »
Ask for that one more time and whenever you start Google you will be flooded with old wallpapers. yes
heat
« Reply #17 on: March 09, 2010, 09:41:36 pm »
Johan, does the below XXHighEnd.exe help you ? (stuff it over your 0.9y-8 folder)
According to your latest post it shouldn't, but I tested all possible combinations here, and it works.
Let me know !
* XXHighEnd-09-y8a.zip (791.27 KB - downloaded 525 times.)
« Reply #18 on: March 09, 2010, 10:01:37 pm »
Oh, and if it still doesn't work (again, what I expect), please post the XX, X3 and X3PB log files. I *will* get this one !
Btw, including that old Wallpaper shown ... which also doesn't happen here. No Clear button should be needed. It just shouldn't be there. Ok ?
nik.d
« Reply #19 on: March 09, 2010, 10:59:19 pm »
Me happy.
 thankyou
Thank you Peter!
(09y-8 of course...)
« Reply #20 on: March 09, 2010, 11:02:22 pm »
.....does the below XXHighEnd.exe help you ?
First track ....yes wallpaper back again!
See attachments.
* X3-20100309-220304.log (50.82 KB - downloaded 515 times.)
* XX-20100309-224215.log (3.38 KB - downloaded 434 times.)
* X3PB-20100309-220304.log (1.95 KB - downloaded 444 times.)
« Reply #21 on: March 10, 2010, 10:31:10 am »
Johan, while we're at it anyway, can you now see (or explain to me) the difference between how the old Wallpaper showed when the new one didn't show at the first track - and how the old shows (if so) now it is working again for the first track ? I mean, it may be so that you can still briefly see the old one, or maybe you don't see the old one anymore ...
« Reply #22 on: March 11, 2010, 09:23:55 am »
....you can still briefly see the old one, or maybe you don't see the old one anymore ...
Setting: Unattended/Show Back/Show OSD text/Wallpaper
What i see in old versions (< 09y-6):
  • sometimes XX shows the old wallpaper from the session before for one second;
  • sometimes no OSD text in the first track;
  • most of the time all works ok.
in version 09y-8a so far
Yesterday i saw during the start of the first track:
  • Windows wallpaper => XX Wallpaper without OSDtxt => OSD-txt => all ok;
  • sometimes XX shows the old wallpaper from the session before for one second, followed by the right one.
« Reply #23 on: March 11, 2010, 10:09:59 am »
Hi Johan. Thank you. I think I saw it myself now yesterday, and it seems (or looks) to be dependend on what you did before. A kind of : when playback automatically ends (end of album etc.) the behaviour is different from when you explicitly stop.
But I will solve it.
And not with a Clear button, if you don't mind ... Happy
« Reply #24 on: March 11, 2010, 03:16:45 pm »
Johan, I think I know how you get fooled by this. IMO this is what happens (or at least can happen) :
1. You let a playlist run until the end;
2. XX Comes up automatically; in this case the XX Wallpaper is still there (debatable whether this is good or not);
3. Start Playack again (from another album);
4. XX vanishes.
5. The still there Wallpaper disappears, because the whole screen briefly gets black, and reappears when the screen is up again (this is Windows);
6. The new Wallpaper shows.
Now, somewhere in between 2 and 4 you are being mislead, because you may not see the Wallpaper, because of XX overlaying it. In your case this is very plausible (very small screen). In *all cases* you will notice the second stage of 5, because the screen turns from black to the old Wallpaper and it for sure is *that* what you will notice. But think further ... just nothing changed, and the Wallpaper is still there, as how it was at #1/2.
What you also won't know (because you can't see it with XX overlaying the desktop) is that Stop is your wanted Clear button; It removes any XX Wallpaper ...
And this is the difference between you stopping and the playlist ending by itself ... there is no Stop. But I think I can fake that, so all gets back to normal ... Notice that this is the same subject as the (same) discussion from a few weeks back, but I only now see what is bugging you, and what can be done about it.
PS: It is also psychologically, because when you click Play you see something changing : From an XX screen to an old Wallpaper. Not so here (and as with most) : the old Wallpaper was there, and stays there until sound of the next begins. Nothing much wrong with that ...
« Reply #25 on: March 11, 2010, 03:26:58 pm »
Okay, that works (0.9y-8b).
Page created in 0.135 seconds with 19 queries.
