April 07, 2025, 01:38:37 am *
Author Topic: No Wallpaper at first track in 09y_7  (Read 25389 times)
« on: March 02, 2010, 06:38:51 pm »
• For Attended Playback the Wallpaper Coverart did not show for the first track playing. Solved.
No Wallpaper during the first track in unattended mode!
« Last Edit: March 02, 2010, 07:34:43 pm by PeterSt » Logged
« Reply #1 on: March 02, 2010, 07:35:55 pm »
(I changed the title a bit)
And at a second track there is ?
glynnw
« Reply #2 on: March 02, 2010, 08:23:18 pm »
No wallpaper for me either- on any track.  Tried Engine 3 and 4.  The bar at bottom with quick start and start icons does appear or disappear as it should when unattended is checked.
« Reply #3 on: March 02, 2010, 10:55:25 pm »
Yes, as always.
Sometimes it still shows, during the first track, the Wallpaper of the session before.
« Reply #4 on: March 05, 2010, 09:55:36 pm »
BTW, to me it shows on first track (while y-6 didnt)
« Reply #5 on: March 08, 2010, 09:03:46 am »
....something like this has been reported, but questions from me about it lead to, well, nothing. So, no opportunity to solve it.
?????? I was hoping that you solved it in version y8!  unhappy
setting: unattended/show back/wallpaper
after <play>-command: sometimes i see the wallpaper from the session before during the first track
second track and further all works ok
Until y5, wallpaper was working ok
Suggestions: Delete old wallpaper after a <clear>-command!
Can you force show wallpaper first, before play? (is that possible?)
« Reply #6 on: March 08, 2010, 09:41:28 am »
Johan, I understand your frustration, but mine is bigger and is on behalf of you (all) ...
I think this topic clearly shows that I can't have a clue whatsoever about what is going on. Somehow exactly nobody ever ran into a situation that it works, and may know what he has changed.
Btw, in two occasions (different topics) I asked to look for ChangeWP running. No answer ...
I just *need* someone who tells me "when I do such and so it works, and otherwise it doesn't".
And to keep in mind : chances are 95% that this is caused by a system not capable of dealing with it because of not enough resources. No matter the second track etc. works. This should (maybe) come forward at just running Engine#3, priorities to Nothing, Scheme to Nothing.
If that doesn't help, it must be a combination of settings somehow. Not that I expect that, but it will be the only thing left.
« Reply #7 on: March 08, 2010, 09:27:47 pm »
I did two attemps to look in Windows Task Manager to see ChangeWP running, but its very difficult to find it in the task manager. Do you have a suggestion to log this activities.
  ....just running Engine#3, priorities to Nothing, Scheme to Nothing.
No wallpaper in the first track after a play command!
edit: even with setting show (mirror) back unticked.
« Reply #8 on: March 09, 2010, 11:04:26 am »
Hmm ... what about posting the X3PB log file ? That should at least show the "ChangeWP Call" entries. The one we would be looking for is "First ChangeWP Call". If that is missing, all should be clear to me, and easy to find (the bug). But if it is there (which is what I suspect), then I don't know.
Allright. I just thought of something else I can look at;
Let playback run into the second track and post both the X3PB and the X3 log files please ...
nik.d
« Reply #9 on: March 09, 2010, 04:45:54 pm »
Re: No wallpaper y9_7 & y9_8
Same with me, no wallpaper 'till 2nd track, sometimes even longer.
BTW, switched back to W7Ux64. Running LineOut to pre/power - this enables me 24/192 dac and Quad/AP or AI ..
Here are the log files, hope this helps. Seems there is "ChangeWP call" however "second" afer some minutes. Log files will tell more.
If this helps: MoBo w/ integrated graphics G31 & 2x1GB RAM
George
* X3PB-20100309-155519.log (0.69 KB - downloaded 554 times.)
* X3PB-20100309-155647.log (0.63 KB - downloaded 545 times.)
* X3PB-20100309-155901.log (0.89 KB - downloaded 555 times.)
* X3-20100309-155519.log (5.37 KB - downloaded 541 times.)
* X3-20100309-155647.log (2.52 KB - downloaded 543 times.)
* X3-20100309-155901.log (14.03 KB - downloaded 539 times.)
« Reply #10 on: March 09, 2010, 05:22:23 pm »
See Attachments
* X3-20100309-162703.log (42.07 KB - downloaded 532 times.)
* X3PB-20100309-162703.log (6.02 KB - downloaded 509 times.)
« Reply #11 on: March 09, 2010, 05:55:56 pm »
Thanks guys, this will enable me to find it ... yes
« Reply #12 on: March 09, 2010, 06:37:22 pm »
Is it true for you both that you didn't ask for OSD Time and Text ?
nik.d
« Reply #13 on: March 09, 2010, 06:44:08 pm »
True for me. Saving resources  Happy
« Reply #14 on: March 09, 2010, 08:04:51 pm »
Ok, it is solved. I will upload it later.
