November 23, 2024, 12:34:41 am *
Author Topic: Am I crazy thinking wav sounds better than flac?  (Read 33136 times)
« Reply #15 on: March 13, 2012, 08:03:08 pm »
Eric, maybe you forgot, but you have a special version; handed to you just for the cause ... many months back already by now ...
(this was about Coverart for the main reason).
Eric
« Reply #16 on: March 14, 2012, 02:22:15 pm »
Yes thank you, I forgot....glad you didn't!
Eric
« Reply #17 on: February 09, 2015, 11:50:10 pm »
Let's start again:
I will make some test's on Tuesday with critical tracks.
NOS1a will reveal differences?
http://www.theabsolutesound.com/articles/new-methods-for-quantifying-sonic-performance-part-two/
See first part of .... .
« Reply #18 on: February 10, 2015, 01:37:07 pm »
XXH is a memory player and is writing the “FLAC to WAV” converted files to ........ , and the CPU has no load during replay.
There seems to be less noise with WAV files, but I would not be able to make a judgment during a “blind test”.
benananda
« Reply #19 on: June 30, 2015, 07:42:22 pm »
Old post, and I haven't been on in years. But, I had to put in my two cents.
In my experience, wav always sounds better than flac. I have had this experience with CD and HD going back and forth, with xxhighend and regular players as well, though I find differences easier to discern on xxhighend. I do not know the reason for it, but i have become a purist over the years, taking out links in the chain to make the signal/source as simple as possible. This is why I use "Pure direct" on my Maranz receiver , rather than Audessey corrections. Recently this premise was validated for me once again, when I found that by simply unhooking the HDMI out from my receiver, the sound changed in a subtle way I would say had more dimension to it. I think you really have to have golden ears here, but I always find the pure wav to be better.
USB to Matrix Mini-i (16bit 48Khz max)  (0.9z-7)
Windows 7 Ultimate 64bit SP1 on SSD, XX on other SSD, music on SATAII spinning disk (on SATA3 port of MB!), MB is Z77 Gigabyte G1 sniper m3, Ivy Bridge i5 3570, / Engine#4 Special Mode / Q1/2/3/4/5 = 2/0/0/0/0 / Q1Factor = 2 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / SFS = 430 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Unattended playback All off especially LAN!
« Reply #20 on: July 01, 2015, 04:57:39 pm »
I never really compare WAV to FLAC, but do you use a RAMDisk as playback drive ?
It should be virtually impossible to perceive differences in that case (but use Unattended Playback).
« Reply #21 on: July 02, 2015, 05:53:46 pm »
No RAMdisk in here, but I didn't notice any SQ differences between FLAC and WAV anymore since my NOS1(a) days. On SQ I couldn't tell them apart.
They are handled slightly differently however by the software though since my FLACs play without hiccups, while the same music in WAV (and all other WAVs) tends to stop for a brief moment after 20-25 seconds. It happens with all XXversions higher than 0.8 yet this hardly bothers me since most of my music is in FLAC for "real-estate" reasons.
regards, Coen
