November 23, 2024, 11:25:49 pm *
Author Topic: y6 in special mode awfully slow  (Read 22928 times)
« Reply #15 on: March 06, 2010, 01:56:01 pm »
The fact that you haven't tempered with that doesn't imply it's correct ...
Right, so i'll check it Happy
« Reply #16 on: March 06, 2010, 08:04:06 pm »
OK, exact same settings. y5-6 is fast and responsive, while y7 is terribly slow, and library goes in loop after 7-8 albums.
Settings showed.
« Reply #17 on: March 07, 2010, 12:15:40 am »
I did more tests and found out that it is NOT the KS/special mode that causes the player to respond so slow. It's just the new version (from y6).
You can't make up your mind, can you ?
scratching
« Reply #18 on: March 07, 2010, 01:47:02 am »
scratching
uh? those two sentences means about the same thing.
I'll make the cpu screenshots.
Tonight i verified that the cpu is stable fanless under load. And, more important for you, irTRANS works in w7 x64 (yup i got it this morning yeah!).
« Reply #19 on: March 09, 2010, 11:04:38 pm »
Solved in y8 for me Happy
wasapi works as responsive as the old versions.
Will check KS tomorrow.
Page created in 0.23 seconds with 19 queries.
