November 24, 2024, 12:55:35 am *
Author Topic: My latency has gone bananas  (Read 6852 times)
« on: February 22, 2010, 03:37:30 pm »
Something is really wrong,
I get glitches all over the place, DPC latency checker is completly red, with sometimes a little green.
But this is when xx is not even playing, hence *its* off. (normal DPC values between 7-15us)(now its over 10.000)
Now even foobar won't play without glitches.
What the hell happened here.
xx also crashed on me this morning,
had to do a new install, because the overall behavior went in slowmotion (not responsive)
Processor core gets a lot warmer than normal. (raises 10 degrees C)(Pc idle at 50 C, normally blow 40 C)
Don't like this behavior at all !!!
Even opening a internet page creates a spike in latency of 7500us !
Sometimes hdd's go on or off, without reason.
What the heck
Roy
« Reply #1 on: February 22, 2010, 03:58:34 pm »
Does this also happen without internet connection ?
If no, possibly a spybot. If yes, possibly a virus.
Sad
« Reply #2 on: February 22, 2010, 04:11:20 pm »
One other option : set your Juli@ to 2048 buffer size and look again ...
« Reply #3 on: February 22, 2010, 04:20:43 pm »
I did looked for virus or bot, still am. (nothing)
latency Juli@ at 2048 doesn't help.
I need to do a clean install anyway.
But I try to do a little understanding in what causing it, can learn from this.
will see
« Reply #4 on: February 22, 2010, 04:31:11 pm »
Yep, sorry its a virus. (again)
again, I'am gonna kill it
Didn't want to cause any panic, but we are working at the edge of hardware
limitations, so better save than sorry
later,
have some killing to do !
