November 23, 2024, 07:24:28 pm *
Pages: 1 [2] 3  All
Author Topic: XXHIGHEND-M2TECH - WIN 7  (Read 42998 times)
gonz
HIFI GEEK
« Reply #15 on: February 23, 2010, 06:03:52 pm »
Maybe start display.exe during playback ?
Tried playing win media player, same result   unhappy
IBM Thinkpad T41 / WIN 7 Ultimate/M2TECH USB/SPDIF device/ACCUPHASE DAC inside DP-67/Interconnect RCA Bertram Ref silver lasertech/Accuphase E-406V intg. amp/Yter silver speakercables/Holfi Thyra Charisma MKII speakers.
gonz
HIFI GEEK
« Reply #16 on: February 23, 2010, 06:16:07 pm »
Hmmm tricky little thing this display ! Started showing the higher value, then suddenly in the middle of the song it change to the smaller value ??
« Reply #17 on: February 23, 2010, 06:37:21 pm »
Ok, on the subject "what is the output", I don't want to panic people, so I'll just show what I see. I can't make anything of it. Maybe others can.
Note that all leads to the thinking the output is 44.1;
a. the number of channels don't decrease;
b. the low right corner shows the output sample rate (at least that's what I always thought because it's always there as at least one sample rate shown, and because the other 176.4 you see a few times don't need to be there at all -> with Firewire connection there is no such thing as a lock).
c. the program DigiCheck (coming along with the Fireface) errors on selecting the input device "illegal device" or something.
Notice though that I am totally inexperienced with SPDIF-In on the Fireface.
gonz
HIFI GEEK
« Reply #18 on: February 23, 2010, 07:50:49 pm »
Hmmm I`ve just used my sampler program loading the a wave 16 bit 44Khz playing it through M2TECH
Then I processed the same wave with the samplers bitdepht converter to 24 bit 96Khz and played this wave through M2TECH as well ! But the dispaly showed the same values 1Khz - 2009019551 bits !
It doesn`t matter if I use XXH , WIN MEDIA PLAYER or the sampler program itself as a player, it still shows the same value no matter what !
« Reply #19 on: February 23, 2010, 08:01:27 pm »
Just wait until tomorrow. With me a took a day too. swoon (just leave it in and leave everything on ... who knows that helps)
But once it started to show the right values, it never showed it wrongly again. Btw, I too saw too different weird high bit numbers, like you.
Anyway, strange.
gonz
HIFI GEEK
« Reply #20 on: February 24, 2010, 04:40:18 pm »
Anyway, strange.
Hmmm still the same problem showing 1Khz and different 10 digits numbers bits ???
I`ve mailed Marco about this awaiting his reply !
gonz
HIFI GEEK
« Reply #21 on: February 24, 2010, 05:39:37 pm »
Could this be a problem with the drivers ??
These are the driver details in my system  !
C:/windows/system32/drivers/dmk.sys  ( digitally signed by MS )
C:/windows/system32/drivers/portcls.sys ( digitally signed by MS )
C:/windows/system32/DRIVERS/vadspdif.sys ( this is the 1.03 driver from M2TECH I wonder if this one is overruled by windows because it is not digitally signed by MS ?? )
Or are they all being used by the system, I`m not all into the technical stuff ?????????????
« Reply #22 on: February 24, 2010, 05:53:05 pm »
The vadspdif.sys is used allright. I received around 672 BSODs from it, before I got it working. Happy Happy (my fault btw, although it is the driver which doesn't comply to normal behaviour really - but no problem).
gonz
HIFI GEEK
« Reply #23 on: February 24, 2010, 07:49:24 pm »
Are your hiface display still showing the true values ???
« Reply #24 on: February 24, 2010, 09:24:40 pm »
I didn't check today, but I'm sure it does ...
gonz
HIFI GEEK
« Reply #25 on: February 25, 2010, 08:23:14 am »
Well OK the most importent thing is still the sound quality ,but it would have been a nice feature if i worked !
« Reply #26 on: February 25, 2010, 08:42:45 am »
Actually, I think we must look at this the other way around :
When you are *not* playing anything, it should say "Hiface S/PDIF by M2Tech". What I recall from when it was not working, is that already at not playing it mentioned that strange rate. Starting playback didn't make a difference. Now it just nicely switches from the text I just mentioned (at not playing), to the proper rate at playing.
Btw, I just checked it for XP, and there it works too.
Maybe it helps if you disconnect the SPDIF cable ?
But I wouldn't bother. It plays.
gonz
HIFI GEEK
« Reply #27 on: February 25, 2010, 12:47:54 pm »
When it`s not ,it says Hiface S/PDIF by M2Tech ,but as soon as I start ,it comes up with 1Khz this is always the same, but the bit value changes fron 7 - 10 digits ! When I point at the hiface display with the cursor and left click holding the button down on the mouse, it changes to 97bits or 40 bits but as soon as I release the button, it goes back to the very very high bit values ! I`ve tried reinstalling the display makes no difference :-(
Did you install the display.exe in the same folder as the M2TECH install ??
I hope to hear from M2TECH about this issue , well if not I`ll survive  Wink
« Reply #28 on: February 25, 2010, 01:17:37 pm »
Yes, but it really doesn't matter, because the "install" you talk about is just a folder with files. The real install (of the driver) happens when you plug in the device in one of the USB ports, and that happens somewhere else (where/what we don't *want* to know about, haha).
gonz
HIFI GEEK
« Reply #29 on: February 25, 2010, 01:23:39 pm »
Well I didn`t think it would matter, but I´m just looking at all ,sometimes you make the silliest mistakes  whistle
Pages: 1 [2] 3  All
