November 23, 2024, 06:54:47 pm *
Pages: [1] 2 3  All
Author Topic: XXHIGHEND-M2TECH - WIN 7  (Read 42991 times)
gonz
HIFI GEEK
« on: February 22, 2010, 01:01:07 pm »
Since I`ve just converted from WIN XP to WIN 7, I think it might be best to start this new topic, to avoid any misunderstanding with regard to my last topic XXHIGHEND-M2TECH-WIN XP.
My first impressions are that XXHIGHEND works smoother in WIN 7 compared to WIN XP with the M2TECH ! But maybe that`s just the case on my CPU !
The sound is very close to highend ,in my opinion, compared to my Accuphase setup !In the next couple of weeks I`ll be testing the M2TECH, using RME Fireface as DAC versus Firewire connection also using RME Fireface 400 DAC !
But thumbs up for Peter  good I must say that the  XXhighend software player has lifted the quality of PC musik playing to a higher level, compared to any other software player I´ve heard so far !
IBM Thinkpad T41 / WIN 7 Ultimate/M2TECH USB/SPDIF device/ACCUPHASE DAC inside DP-67/Interconnect RCA Bertram Ref silver lasertech/Accuphase E-406V intg. amp/Yter silver speakercables/Holfi Thyra Charisma MKII speakers.
ivo
Music lover
View Profile WWW
« Reply #1 on: February 23, 2010, 12:16:16 pm »
Hey gonz,
Have you tried HiFace via XXHIGHEND in 24/88 and 24/176 modes using engine#4? Does it play smooth without interruptions?
Ivo
gonz
HIFI GEEK
« Reply #2 on: February 23, 2010, 12:48:19 pm »
Hey gonz,
Ivo
Hey Ivo
I haven`t got any hd music samples to test this yet ! I`ve only been playing cd quality 16bit/44Khz ! My settings are 32 bits and KS special mode in engine#4 and this works flawlessly ! I`ve fooled around with all the settings that are available in the DEMO version og XXH ! Everything runs smoothly
untill now  pleasantry
Earlier before I converted to WIN 7 i had some 24bit/96Khs samples and strangely enough M2TECH dosen`t show the right values on the DAC display, it showed 48Khz  instead og 96Khz on the display of my Accu DAC ! I had a talk with Marco ,at M2TECH about this, and he assured me that the M2TECH is playing 96Khz even though it shows otherwise ! It`s a slight problem with the M2TECH ! I`m not qualified to go into this any further ,so you`ll have to contact M2TECH if you want the full technical explanation  wacko
I the next couple of weeks me and a pal of mine are gonna do some hardcore testing soundwise !
WIN7-XXH-FIREWIRE- DAC RME FIERFACE400 16bit-24bit-32bit
WIN7-XXH-M2TECH- DAC RME FIREFACE400 16bit - 24bit -32bit
WIN7-XXH-DAC Accuphase DP-67- 16bit - 24bit
WIN7-FOOBAR-M2TECH-DAC RME FIREFACE400 - 16bit - 24 bit
The end results will be posted as soon as possible  Wink
PS: Just to avoid any misunderstandings, this will only be our opinion of the sound quality, on our setups ! Someone might not agree with the result we come up with, and it might be the case that the result would turn out differently on other setups  Cool
« Reply #3 on: February 23, 2010, 01:05:18 pm »
Hi Gonz,
If you tick Double you'd have 88.2 and for Quattro 176.4. I guess this is what Ivo wanted to know. You can do that in demo mode just as well.
Further, the 1.03 driver version contains a display.exe and it shows in a small display what the HiFace is receiving. Of what I saw from it this is always correct. This includes feeding it with 24 vs. 32 bits (because it can cope with both). Notice that I can check this with my driver software, similar to how the Fireface will be able to show you the input rate, as received from the HiFace output.
oops ... Having said that ... oops
When the Fireface receives 176.4 input it switches to a mode with less channels (than the normally 52 or whatever available). This shows easily in the mixer screen because it gets smaller (less channels to show). But ... I don't think I saw that happening !! So I must check that !
If you are confused : The check I can do as mentioned in the first part above, is checking what the HiFace receives. So, if it says it receives 32/176.4 it actually does because I can check that with another driver. But what I realize now is that this doesn't say a thing about the ouput of the HiFace ... which can be checked easily with something like a Fireface when it's behind it. Suddenly I fear the worse ... and you may just be right on your observations, gonz.
Will let you know later today.
gonz
HIFI GEEK
« Reply #4 on: February 23, 2010, 02:48:07 pm »
Hey gonz,
Ivo
Actually I have tried playing with the double ticked 24/88 and it works without any problem !
gonz
HIFI GEEK
« Reply #5 on: February 23, 2010, 03:09:30 pm »
I didn`t notice  that  blush1
I´ll try it out as soon as i get home  Wink
ivo
Music lover
View Profile WWW
« Reply #6 on: February 23, 2010, 05:01:42 pm »
Just ordered the HiFace unit and as I will be using it with laptop (I have only USB ports at its sides) found an interesting adapter exactly matching HiFace's needs!!!
http://cgi.ebay.com/Flexible-swivel-Angle-360-Degree-Adjustable-USB-Adapter_W0QQitemZ140367089285QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item20ae87ce85
I was wondering if this cheap stuff does not make the communication between HiFace and PC worse? But it is hell of convenient....still
Ivo
gonz
HIFI GEEK
« Reply #7 on: February 23, 2010, 05:11:58 pm »
Hmm can`t seem to find display.exe do you mean with the M2TecH drivers ??
« Reply #8 on: February 23, 2010, 05:19:00 pm »
Yes ...
* display.zip (224.21 KB - downloaded 544 times.)
gonz
HIFI GEEK
« Reply #9 on: February 23, 2010, 05:25:44 pm »
Yes ...
Thanks I didn`t get this in my zip files from Marco  Happy
gonz
HIFI GEEK
« Reply #10 on: February 23, 2010, 05:37:28 pm »
Hi Gonz,
This is obviously way beyond my technical insight  unhappy
I`ve installed the display but when I play KS engine#4, it shows, Hiface playing 1Khz  1244768 bits ??
What does this actually mean ????
« Reply #11 on: February 23, 2010, 05:47:27 pm »
Funny ... at first I had this exactly the same, and thought it was a useless program. Then later, when I finished with everything, I tried it again, and time after time it showed reality.
At least try it with a setting in XXHE of which you are sure it works good, like Engine#3. I mean, suppose you are loosing samples, it (that display.exe) may get confused.
gonz
HIFI GEEK
« Reply #12 on: February 23, 2010, 05:56:44 pm »
Now i tried again on engine#3, at first i was the same, then I stopped playback and started again, now  it says 1Khz 2009019551 bits ?????????????????+
« Reply #13 on: February 23, 2010, 05:59:57 pm »
Maybe start display.exe during playback ?
gonz
HIFI GEEK
« Reply #14 on: February 23, 2010, 06:00:49 pm »
Done that no change !
Pages: [1] 2 3  All
