November 24, 2024, 01:35:19 am *
Author Topic: Where does XXHE get its album cover art?  (Read 6906 times)
DannyD
« on: February 21, 2010, 08:14:08 pm »
I have one artist in my library where each album I rip ends up with the same album cover.  I rip with dbpoweramp and when I look in the resulting directory for each album the file folder.jpeg had the correct cover art, but by the time XXHE displays it, all albums for that artist have the same album cover.  What should I do?
« Reply #1 on: February 21, 2010, 08:31:24 pm »
Hi Dan,
Look one or two folders up. There you will find the dreaded one. Delete it, and it will be allright.
DannyD
« Reply #2 on: February 21, 2010, 08:40:57 pm »
Sorry, Peter... what folder and file am I looking for where?
« Reply #3 on: February 21, 2010, 09:05:40 pm »
Hi Dan,
Look in that *one artist* folder like you said.(or somewhere up in that directory)
And look for the image that keeps popping up. (called folder.jpg)
Just take it out and see what happens. (or rename it to something else)
Roy
DannyD
« Reply #4 on: February 21, 2010, 10:43:19 pm »
Thanks, Roy.  I ended up brute forcing it by deleting everything related to this artist on my entire music server and re-ripping it.  Problem solved!
