November 23, 2024, 07:05:30 pm *
Author Topic: 0.9-y6 can`t find my music files  (Read 20818 times)
tillen
« on: February 21, 2010, 01:03:41 pm »
I can only play a few music files with the newest version. I get a error message witch says con not find the file. Can not find that there are spesial files, like flac or wav, it wont play. I Have tried several different settings. the Q1 set to -4 is the only setting i can get proper sound with. In previous versions it works fine.
PC- Asrock X79 Extreme 4-M -
« Reply #1 on: February 21, 2010, 01:12:46 pm »
Did you install everthing in a new folder ? if not, you may try that. It should be about something being inconsistent ...
tillen
« Reply #2 on: February 21, 2010, 01:17:17 pm »
I think I was a little to exited with the first install. But i reinstalled it in a new folder, and the problem was the same. I`ll try a new install now.
tillen
« Reply #3 on: February 21, 2010, 01:54:32 pm »
Nothing changed. New install, but the same fail. Caller: G can`t find the file C:\XXHighEnd\0.9-y6\UnicodeTrack0001.wav. And: Music File does not exist (1) : UnicodeTrack0001a.wav.
* X3PB-20100221-133504.log (0.02 KB - downloaded 567 times.)
* X3-20100221-133504.log (0.42 KB - downloaded 563 times.)
« Reply #4 on: February 21, 2010, 02:10:50 pm »
It looks like you are using Anti Imaging for upsampling; This should work by itself, but is largely dependent on other settings and I sure won't have tested all the combinations. But ... is it your intention to use AI ?
Did you use AI there too ?
tillen
« Reply #5 on: February 21, 2010, 03:31:52 pm »
I have used AI since it came. But you were right as allways, AI off, and then it works. Thanks Happy
« Reply #6 on: February 21, 2010, 03:43:22 pm »
But you want it fixed I suppose ? In that case, please post your XX log file, because I really need that one. Do that together with the X3 log file from "the" situation. X3PB is not needed.
tillen
« Reply #7 on: February 21, 2010, 08:30:41 pm »
Suppose so. Here are the log files for "the" situation. And from one who plays with AI.
* X3-20100221-200931.log (0.42 KB - downloaded 533 times.)
* XX-20100221-200442.log (5.39 KB - downloaded 558 times.)
* XX-20100221-200948.log (11 KB - downloaded 511 times.)
* X3-20100221-201256.log (2.1 KB - downloaded 552 times.)
* XX-20100221-200948.log (11 KB - downloaded 544 times.)
* XX-20100221-201322.log (4.13 KB - downloaded 551 times.)
« Reply #8 on: February 21, 2010, 08:32:55 pm »
Thank you. I will look into it !
« Reply #9 on: February 22, 2010, 01:39:34 pm »
Similar (same?) issue with a Coldplay cd just happened.
Some clue can be in the xx log file (attached). So far it is the first time i get this error.
* XX-20100222-131724.log (34.95 KB - downloaded 599 times.)
« Reply #10 on: February 22, 2010, 05:08:51 pm »
Hi Telstar. What do you mean ? I don't see you applied the Anti Image upsampling filter ...
So now my question is : what exactly when wrong in your case ?
And whatever it was, can you find the X3 file going along with the XX file you posted ?
Thanks.
« Reply #11 on: February 22, 2010, 05:26:06 pm »
No, it cant play no matter if i use a filter.
Plain vanilla now and see attachments.
* X3-20100222-171106.log (0.29 KB - downloaded 545 times.)
* X3PB-20100222-171106.log (0.02 KB - downloaded 531 times.)
* XX-20100222-171034.log (28.15 KB - downloaded 544 times.)
« Reply #12 on: February 22, 2010, 06:38:29 pm »
Telstar ... there's a line in the XX log file that tells me you received an error message about FLAC decoding erroring out.
Please ... too much !
« Reply #13 on: February 22, 2010, 07:14:11 pm »
tillen - For the life of me, I can't find what is going on here. I tried to play exactly the same as you, but here it just works. However, I see a difference in your log file and mine. Look :
Yours
20:09:28.3391970 : AA encoding start for processor 1
20:09:28.4171970 : AA encoding applied for processor 1
20:09:31.4591970 : Attended Playback finished waiting for conversion for processor 1
20:09:31.4591970 : Start Conversion (T)
Mine
17:57:54.0718934 : AA encoding start for processor 1
17:57:56.6458979 : AA encoding applied for processor 1
17:57:56.6458979 : Attributes (1) set for processor 1
17:57:56.6614979 : Attributes (2) set for processor 1
17:57:56.6926980 : Attended Playback finished waiting for conversion for processor 1
17:57:56.6926980 : Start Conversion (T)
It looks like your encoding didn't do anything (it can't be done in 0.08 seconds I think) plus those lines about the Attributes are not there in your case, and the code tells me again that the conversion didn't take place. You don't have a more than 4 core processor, do you ? or what about those new Q core processors with 4 cores PLUS hyperthreading ? That would be 8 cores, and the program just won't recognize more than 4, but if more, it doesn't do anything I see now.
tillen
« Reply #14 on: February 22, 2010, 10:25:05 pm »
No, I have a Core2 duo T5550. The funny thing is that it plays on only 2 albums with AI. and I`ve tried to compare these with and without AI, but I can`t hear differense i sound quality by now.
Page created in 0.128 seconds with 19 queries.
