November 24, 2024, 04:54:25 am *
Author Topic: No wallpaper!  (Read 10925 times)
« on: February 21, 2010, 12:44:10 am »
My wallpaper doesn't work in Unattended mode...
Robin Hood
« Reply #1 on: February 21, 2010, 12:57:07 am »
It doesn't work in At Attended either.  I assume this is something minor to fix.
« Reply #2 on: February 21, 2010, 01:15:13 am »
At the second track i have the wallpaper back!
« Reply #3 on: February 21, 2010, 07:35:12 am »
Hmm ... Because this is a nasty cpu eating thing, I tried my best to give it the least resources possible. Now it just may get to few to ever finish ? On that matter, do you see ChangeWP.exe appear in TaskManager ?
Can you guys please try to look whether it makes a difference if you play with the priorities ? *and do not set Q1 so low !* (just to find out what the culprit is).
« Reply #4 on: February 21, 2010, 04:34:45 pm »
....if you play with the priorities ?
After lowering the threat Prio, XX shows me one time the wallpaper (exlusive OSD text) direct after a play command. In the second track it shows also the OSD text. But all the other sessions it shows the first time the windows background. The next tracks works ok. It looks like changing the prio did not solve this wallpaper problem. Further lowering the treat prio gives cracks in the sound. So i'm back now to realtime. What i also see one time after a start of a new session was the wallpaper and track names in the back from the session before!?!?!? When i stop this session and looking in the playlist it shows me only this new selection.
Johan
« Reply #5 on: February 21, 2010, 05:33:39 pm »
But what about Normal Mode and a not so low Q1 ?
« Reply #6 on: February 21, 2010, 08:41:35 pm »
Sorry, it makes no difference.
« Reply #7 on: February 21, 2010, 08:54:26 pm »
....What i also see one time after a start of a new session was the wallpaper and track names in the back from the session before!?!?!?
Looking a whole track to the coverart of the session before. Please delete the wallpaper after the session is finished and the user gives a Clear command of the playlist. The second track all works ok.
« Reply #8 on: February 21, 2010, 11:02:33 pm »
Easy to say, when I don't have a problem with it in the first place ! I even wouldn't know how to test it ... (because it doesn't happen here).
But I'll try to find your something ... Happy
