April 05, 2025, 12:04:12 pm *
Pages: 1 2 3 [4] 5  All
Author Topic: XXHighEnd Model 0.9y-6  (Read 76503 times)
Eric
« Reply #45 on: February 24, 2010, 11:19:22 pm »
For the record:
I can't get any better than Q1=22 (587) with Buffer Size =768 playing QAP Double.
My interface is Firewire to Fireface400 followed by SP/DIF to TwinDAC+ (battery powered).
The sound however is absolutely marvelous, using Double only because my DAC doesn't accept Quad.
Eric.
« Reply #46 on: February 25, 2010, 12:50:50 am »
Also for the record,
with USB I can get very low (2 samples), but only one channel is working, guess a DAC problem.
With firewire/SPDIF I can listen at highest Q-rate and only 88 samples in the Terratec, but with constant rattle.
earflappin
« Reply #47 on: February 25, 2010, 01:49:31 am »
I'm now running 32 buffer size on both XXHE and my Lynx AES card with Q1 sample size of 3 with no QAP and its the best sound I've ever gotten from my system.
I've also found that AES cables make a big difference in SQ.  I started off with a DH Labs 110 cable which was a step up from the stock Lynx cable and the Gotham cable.  Then I switched to a custom Cardas Neutral Reference DB25/XLR cable and the improvement was immediate and not subtle.
Once Antelope starts shipping their Zodiac DAC's I'm going to get one to reclock and noise isolate the AES output from my Lynx card.  I'll also be able to A/B an async USB interface vs the AES interface.  Should be interesting.  Again, I don't see why async USB shouldn't be superior to AES.
« Reply #48 on: February 25, 2010, 07:11:42 am »
Gerard - Interesting ... That is, at a higher setting the two channels start to work ?
« Reply #49 on: February 25, 2010, 08:57:22 am »
I have the same DAC and i am playing at 5 samples and everything is working great!! Below this 5 there is no sound on both the channels.
ivo
Music lover
View Profile WWW
« Reply #50 on: February 25, 2010, 12:53:03 pm »
Can confirm once again my current setup:
SETUP: Dr.DAC2 over USB, No upsampling, DAC is set to 24/96, all Qs=0, Special mode, buffer=32 (the smallest), playing 16/44 and 24/96 material. All this on Vista HP.
SOUND: Crackless, popless and very nice!!! Stereo amazing, space huge - very well. However, CPU constantly at 25- 35 % during playback. I have AMD Athlon 64 Dual core. Otherwise files are loaded and converted FLAC-->WAV very fast. I am satisfied with the latest XX.
FUTURE: Waiting on HiFace unit, so I can go into DAP and QAP world with Arc Pred. Maybe someone can share the lowest settings for engine#4 with HiFace?
Ivo
« Reply #51 on: February 25, 2010, 01:19:05 pm »
I don't know about the lowest setting, but I used it with 22 (samples).
« Reply #52 on: February 25, 2010, 01:27:18 pm »
No, I would wish so!
I guess they made a bad USB-to-SPDIF converter in China for my DAC.
I don't think Left and Right get seperated before the input/samplerateconverter but it looks that way.
Or it must be the USB-codec in the PC, since 'test' is also like that.
« Reply #53 on: February 25, 2010, 04:45:37 pm »
... meaning the sound going bananas at a volume change (or Absolute Phase change) at the ultra low latancy settings ... this is a bug, so to say. Notice that I'm talking about the situation that the OSD Time would turn white, which is at track (part) boundaries.
I only want to say : if you calibrated everything including being able to cope with this ... the next version won't make "fuzz" Happy about this anymore.
« Reply #54 on: February 25, 2010, 11:47:21 pm »
It's working on USB!
Both channels. I think it's the shorter USB-wire that made the difference but not 100% sure.
Don't want to break it to find out...
It plays 16/192 max so no arc, don't know if it sounds better, but it sounds good.
« Reply #55 on: February 25, 2010, 11:59:18 pm »
Me having a real short USB cable so you may be right on that!
 good
(I never have enjoy music so much as i have done these past week) (Really!)
« Reply #56 on: February 26, 2010, 01:03:35 am »
Haha, Everything is better now with your new little babyboy!!!   drinks drinks
Yeah, but that means the Dac has to take the place of the recordplayer, oei, oei...(ai, ai)
« Reply #57 on: February 28, 2010, 01:18:17 pm »
Peter, I love ya man and appreciate the progress on sound quality, but is there any way to de-geek the GUI?
Amen!
« Reply #58 on: February 28, 2010, 01:33:50 pm »
Just wait a bit. I'm improving the sound here.
I think.
too much !
« Reply #59 on: February 28, 2010, 02:11:16 pm »
I think.
too much !
 rofl Why am i not suprised!  Wink
         Go Jerry Go Jerry.... yahoo
