April 05, 2025, 12:26:54 pm *
Pages: 1 [2] 3 4 5  All
Author Topic: XXHighEnd Model 0.9y-6  (Read 76506 times)
« Reply #15 on: February 21, 2010, 04:16:39 pm »
And Russ, did you check for the lot being bit perfect ? I mean, don't be disappointed if it isn't.
I am *not* implying that what you have running, can't be. I just didn't go lower than 5 samples myself because I thought it would be rediculous. So, I stay on 22, and know you might have better sound. Why not, haha.
« Reply #16 on: February 21, 2010, 04:23:12 pm »
You guys keep on saying that each time ! You don't want me to keep on believing that, right ?
swoon
Take all compliments you can get
You won't get them about your good looks, hehe
Then we would be lying for sure
« Reply #17 on: February 21, 2010, 04:48:47 pm »
In both (un)attended modes i can have the Q1 slider at -2 ( 1 sample ) and play back my 48kHz DTS encoded albums fine Happy
Data-1 : 0.02  Data-2 : 1.6  Data-3 : 12  Data-4 : 1  Data-5 : 48
-17
-18
-19
-28
-29 (Start Playback)
Special Mode !
First ChangeWP call
Russ ( with the pedal to the metal ! )
« Reply #18 on: February 21, 2010, 05:03:13 pm »
The Audiotrak Prodigy HD2 is working in KS mode (engine#4) in Special mode Q1=4 (parameter=22). The sound is great!!! Detaills,detaills, stereo effects are great,....I think ....the best sounding version so far. Congratulations! Did you hear the last Yello cd "Touch Yello"? Very spectacular sound!
Sometimes i hear a small hickup/crack in the sound! What is the best strategy to solve this? I suppose to set the Latency of the soundcard to the lowest as possible value. The Split file size back to 100. Treat Prio= Realtime. Changing these values back didn't solves it anymore.
Johan
« Reply #19 on: February 21, 2010, 05:25:59 pm »
Hi Johan - Thank you very much.
No, it is not necessarily true to use the lowest buffer setting on your sound card. E.g. for me I have to set it to 128 for the 22 sample Q1 setting. 64 works too by I don't like the CPU usage coming from that, and 48 just doesn't work without regular ticks (or small skips). So, it depends ...
In a next version I will try to make something (out) of this.
« Reply #20 on: February 21, 2010, 05:31:09 pm »
heatheat
You may not believe it, but I really didn't dare to check it myself. I just didn't want to know it if what I perceive as extraordinary good, would be specifically wrong. This is why I gave the piano example, because it really is special (I won't tell what so others can discover it) and leads to the suggestion of something being wrong. Well, as I told in the release notes.
« Reply #21 on: February 21, 2010, 05:42:10 pm »
I'm new to the forum but tried the different versions of the last months.
Hi Georg, welcome. It's a great time to join the XXHE 'club'...
« Reply #22 on: February 21, 2010, 09:59:21 pm »
i have connected the dac trough usb and now it does work...
No, not here.
I think I'll go back to the previous version, there I played LOUD, now I don't feel like doing that anymore.
Maybe the disappointment-placebo-effect?
Peter, can I just put the old version over the new one? (Backups why?)
DannyD
« Reply #23 on: February 21, 2010, 10:27:17 pm »
What's a good target CPU usage?  I'm not getting any ticks but my CPU is at 24%.  My buffer size in XXHE and on my Lynx card is 32, and my Q1-Parameter is 16.
Dan
« Reply #24 on: February 21, 2010, 11:07:16 pm »
Should be just virtually zero Dan. A constant 24 % ... hmm ... but that can be because of a just "under powered" processor. But I have serious spikes at illogical moments, coming from the driver. Like once in the 5 seonds (and there's nothing "I" (XX) do once in the 5 seconds ... this, while it influences SQ).
« Reply #25 on: February 21, 2010, 11:12:08 pm »
No, not here.
Sorry that it doesn't work out for you Gerard.
If you know wat you are doing you can put anything over anything ... but you can also just download the base version (0.9y-5-00) again, and paste over that the 5 version you like.
DannyD
« Reply #26 on: February 21, 2010, 11:15:52 pm »
To reduce CPU use, am I better off increasing Q1 or changing buffer to a higher setting?
« Reply #27 on: February 21, 2010, 11:45:00 pm »
Increasing Q1 helps, but relatively little. What the influence of the soundcard's buffer is you can only see yourself. Notice that the cpu useage a soundcard's (etc.) driver may incur for (the amount of it) allows for playing 100 tracks at the time ... that bad. And to keep in mind : it is the spikes (like once in the x seconds) which are bad. A constand useage is okay, whether it is near zero or 24%.
All IMO.
earflappin
« Reply #28 on: February 22, 2010, 12:35:00 am »
I have the Lynx AES16 card on Win7 like Dan and I'm getting a CPU usage of a fairly stable 5-7% with my Lynx card and XXHE Special Mode buffers at 32 and Q1=16.  If I move Q1 to zero it increases the CPU usage to 34-40%.  I'm still experimenting.
DannyD
« Reply #29 on: February 22, 2010, 02:00:50 am »
Earflappin,
Which Q1 value of 16 do you mean?  The tool tips value or the old one?  When I set the old value of Q1 to 16 (tool tip value of Q1 = 35), my CPU-utilization is 7-9%.  When I set the tool tips value of Q1 to 16 (old Q1 value = 5), my CPU utilization is 19-21%.
Dan
Page created in 0.018 seconds with 19 queries.
