April 05, 2025, 03:41:25 pm *
Pages: 1 [2] 3  All
Author Topic: S/PDIF Cable  (Read 50964 times)
« Reply #15 on: February 15, 2010, 05:13:20 pm »
i2s connectors do not exist, since i2s does not exist as external connection.
FW cables should not be all that important, because what's transferred over them is just digital and error checked.
Btw, I once tried to make a FW cable myself, but it didn't want to work. Never understood why.
« Reply #16 on: February 15, 2010, 05:29:40 pm »
Yes, you are right!
What connectors are you planning to use on NOS1 then??
RJ-45 DIN/cat5 connector or some other 5/6 pins mini-DIN connector.
I think CAT5 can be an option for the cable, also from Belden 1585A (Teflon) or something like that.
« Reply #17 on: February 15, 2010, 05:41:28 pm »
There are I2S Cables Available
But is there a standard, guess not. (ISO)
« Reply #18 on: February 15, 2010, 11:25:58 pm »
None ... No external i2s for sure ...
« Reply #19 on: February 16, 2010, 12:02:03 am »
With your plans do we still need a SSD in PC for better SQ ?
« Reply #20 on: February 17, 2010, 12:14:57 pm »
I don't actually use RCA spdif cables in my setup (I use dual-wire AES for signal and BNC for wordclock, between the Weiss and PMII). However, I came across this thread quite a while ago that intrigued me: http://goodsoundclub.com/Forums/ShowPost.aspx?postID=5565#5565.
From the thread, apparently the old Belkin Synapse Platinum Digital cables (the blue ones from the 1990s) are the 'dog's bollocks', as we say here in the UK. You may notice that there is a poster called 'miab' who is offering these cables for $65 each plus shipping. I've just ordered a couple of these from him, and they should be in the post to me right now. I'm hoping to be able to convert one to BNC and use it for my wordclock. Assuming I don't screw it up and need the other one, I may have one spare. I'd be happy to sell it for the price I paid for it (even if I'm hit with customs duty, the price shouldn't be more than £60 plus shipping). Alternatively, you might want to contact miab directly to ask if he has more...
If you're thinking of another solution, one thing to bear in mind is that cable length is important. Some people believe that too short is no good! See http://www.positive-feedback.com/Issue14/spdif.htm.
« Reply #21 on: February 17, 2010, 12:33:11 pm »
IMO this would be specifically true when the termination isn't right. And ... with any 75 Ohm cable and RCA connectors this would be the case (not correctly terminated). So, you'll get reflections, and the longer the cable, the less impact the reflections have (onto the original output).
(I didn't read that link, and I hope it tells similarly Happy)
« Reply #22 on: February 17, 2010, 12:49:21 pm »
Thanks Mani. I'll definitely check out that thread, though I've settled on a solution. My next question concerns interconnects. Having read this article, http://consumerist.com/2008/03/do-coat-hangers-sound-as-good-monster-cables.html, a while ago, I've never taken them too seriously. However, after hanging around here for the last year or so I think I need to ask: anyone have suggestions on interconnects? How much do they matter?
« Reply #23 on: February 17, 2010, 12:57:23 pm »
You're bang on. So, you're not just a pretty face after all Wink
« Reply #24 on: February 17, 2010, 01:06:40 pm »
Forgot to ask: So whats the optimal length for an S/PDIF cable, 75 ohm, rca connectors?
« Reply #25 on: February 17, 2010, 01:21:17 pm »
...anyone have suggestions on interconnects? How much do they matter?
How big is your can for the worms that'll sprawl out of asking such a question?
FWIW, many years ago, I tried more (analogue) cables than I can remember - both interconnects and speaker cables. I spent a veritable fortune on this endeavour.
I found that I really didn't like silver-plated or solid silver... at all. No matter what the make, or price (and I'm talking thousands of dollars here). I even tried solid gold (yes, solid gold) which I liked a lot more than any silver one. I actually still have these... but have them 'wasting away' in my office system.
There were two makes/models that I preferred over all the others.. and they were a fraction of the price of the silver/gold ones I tried. One was Van den Hul 'The Second' interconnects and speaker cables. Probably too 'dark' for most people, but such a natural and full tonal texture. The other was Analysis Plus Solo Crystal interconnects and speaker cables. Indeed, I use these exclusively in my main system - with active crossovers and 8 amps, as you can imagine, I'm using a lot of these cables. I didn't care at all for the more expensive Analysis Plus silver- and gold-plated cables - I actually hated the former.
Now, I'm certainly not suggesting that you do what I did - actually buy the cable then sell what you don't like at a massive loss, if at all. (In fact, I probably have the world's most expensive cabling in my car, becaue I couldn't sell it. But my car is so noisey that I can't hear a thing anyway!)
Try to find a retailer who will let you return what you don't like... that's my only advice really.
« Reply #26 on: February 17, 2010, 01:22:24 pm »
Over 1.5m, according to Dan Lavry...
« Reply #27 on: February 17, 2010, 01:42:15 pm »
Actually, that's not my only piece of advice. On top of this, I would say stick with good quality pure copper over anything else (except maybe carbon). Even then, the insulation material/geometry will have an effect, and this is why you're going to have to listen to it in your own system.
A final thought - don't forget that there will be cabling inside your electronics and speakers that may ultimately act as the weakest link. This is why I have my speaker cables soldered directly onto my speaker drivers. But I don't intend to do the same thing with all my electronics!
If I had to do it all over again, I'd stick with cheap OFCC cables from my local electronics supplier... honestly. There are far more important nuts to crack, IMHO... like taking the digital 'glare' out of digital - something that Engine#4 looks like it's going to help us do.
« Reply #28 on: February 17, 2010, 01:44:41 pm »
Again, thanks Mani!
« Reply #29 on: February 17, 2010, 01:49:56 pm »
About my earlier mentioned "don't go over 1m for SPDIF" ... a long time ago I learned by heart (from whereever) that 90cm would be a good length. Today ? I don't know. I have always be ignorant and used a cable as short as possible with 75 Ohm RCA connectors (they do exist). So, now I indeed read that article from/about Steve, and when the internal circuitry doesn't comply to 75 Ohm termination, YMMV.
In the mean time I read this a while back from Steve, and I think it is really good : http://www.empiricalaudio.com/computer-audio/audio-faqs/short-versus-long-cables
This is about the tradeoff between long interlinks and short LS cables, and vise versa.
Pages: 1 [2] 3  All
