« on: February 15, 2010, 01:19:57 pm » |
I'm currently connecting my usb/spdif converter (M-Audio) to my dac with a 12 inch, six dollar spdif cable. In anticipation of getting the Hiface happening, I am wondering if upgrading such a short cable will make much of a difference. Prices of cables are really unbelievable. Is a .5 meter cable that costs $125 really worth it?
« Reply #1 on: February 15, 2010, 01:56:57 pm » |
Hi Boleary,
If you are handy, you can DIY, I have a nice recipe.
Belden 1694A or 1505A coax cable with Eichmann Silver Bullet RCA Plugs.
It will cost you half the price (depends on costs Eichmann) and much better sound then any prefab. This will sure make a difference for the better. Don't spend high amounts of money on a cable, you will be disappointed.
« Reply #2 on: February 15, 2010, 02:15:04 pm » |
Thanks Roy. I'm sorta handy and could probably handle this task. The Eichmans are expensive and I assume are totally worth the cost.
« Reply #3 on: February 15, 2010, 02:23:09 pm » |
I have already made a dozen of these for my friends. This cable is best value for your money.
I can made a guide on how to build, material list etc. Its not that hard, the only thing you should worry about is not firing up your eichmanns with a too hot solder iron. If you can't get Belden cable, I can send it over to you. (availability depends on continent) And look for a good price on the eichmanns, because they are sometimes sold for twice as much.
Roy
« Reply #4 on: February 15, 2010, 02:35:03 pm » |
Just checked.........I still have some mtrs of Belden 1694A. And have an adres here in Holland for the SilverBullits. They also deliver per/two
If there is interest I can make some more.
« Reply #5 on: February 15, 2010, 02:37:03 pm » |
Again, thanks Roy. If you are willing, I'll take a guide since I've never done it before, otherwise I can ask Uncle Google. The cheapest I've found the Eichman's thus far is $139 for a set of 4. Know anyone who sells just a pair or is four the minimum amount?
« Reply #6 on: February 15, 2010, 02:44:51 pm » |
Of course I'm interested. Just sent you an email.
« Reply #7 on: February 15, 2010, 03:23:57 pm » |
You could also use the copper bullits they are much cheaper. But if you choose the copper version, you could also take any kind of RCA. Just made a phone-call on the silverbullits, they cost 24euros each complete cable costs about 90euro incl pp. (and will look better then the one on pic) But keep in mind a standard I2S connection will do much better. But who has I2S, at this point!
« Reply #8 on: February 15, 2010, 03:31:38 pm » |
« Reply #9 on: February 15, 2010, 03:46:30 pm » |
Btw, I don't want to discourage anyone, but keep in mind the current currency rate, which is 1.36. IMO a good digital cable is more important than a good interlink. And boleary, on this matter, using RCA connections on a 75Ohm cable is not the best thing to do. That should be BNC ... (hence, you don't want to change something about the HiFace, right ?  ) (*and* those cables  )
« Reply #10 on: February 15, 2010, 03:56:43 pm » |
IMO a good digital cable is more important than a good interlink. I think both are equally important, but I did lots of expermenting on SPdif and some are sounding truly awful. And boleary, on this matter, using RCA connections on a 75Ohm cable is not the best thing to do. That should be BNC ... (hence, you don't want to change something about the HiFace, right ? )
BNC is the best connection for SPdif, but you need a special tool to make a decent BNC connection. Hiface is also in BNC available, what about your DAC ? Otherwise its best to use Canare BNC connectors. Next best is the Eichmann Silver Bullit (or equal)
« Reply #11 on: February 15, 2010, 04:01:37 pm » |
Well, BNC sounds great but my dac 's spdif input is rca. It also has a balanced AES/EBU but no way to use it.
« Reply #12 on: February 15, 2010, 04:10:27 pm » |
This will be your problem too, Peter ! How much for NOS1 in Dollar ??
han
« Reply #13 on: February 15, 2010, 04:23:17 pm » |
Hmm, This discussion gives me the chance to pose my question about Firewire cables again.... Am I right that even the quality of cables in the digital part are important if we consider SQ? Anybody experience with Firewire cables maybe?  Regards, Han
i7 core, HT on//Windows 7 prof. 64//XX High End 9z-5 on SSD // *Engine#4* //special mode// Q1/2/3/4/5 = -/14/0/0/0 // scheme 3// Playerprio = Low // ThreadPrio = RealTime // /Services Off// 4x Upsampling //sfs 90//clock res 1 ms//straight contiguous// Weiss DAC 202 // NAT Magnetostat Pre-amp// NAT Magma M monoblocks // Kaiser Kawero// Siltech Signature
« Reply #14 on: February 15, 2010, 04:28:42 pm » |
The best connection is NO connection, so everything in between will alter SQ.
I can imagine for FW that will be the same. (or I2S) (or wait for super-conductors)
I don't know if there are good connectors available for DIY, cable is not the biggest problem.
But are there decent FW or I2S connectors on the market yet ?
I dunno....
