November 23, 2024, 05:16:54 pm *
Author Topic: 0.9y-5-06 crashes after ALT+N  (Read 6217 times)
claus
« on: February 15, 2010, 09:31:25 am »
Hi everyone,
congratulation and thanks to Peter for remarkable soundquality.
1.
Why does XXHE crash everytime I press ALT+N for 'next track' as long as there is a next track in the playlist. No crash if there is no next track in the playlist. In this case XXHE just keeps on playing.
Problem Event Name:   APPCRASH
  Application Name:   XXEngine3.exe
  Application Version:   0.0.0.0
  Application Timestamp:   4b72f31d
  Fault Module Name:   KERNEL32.dll
  Fault Module Version:   6.0.6002.18005
  Fault Module Timestamp:   49e037dd
  Exception Code:   e0434f4d
  Exception Offset:   0003fbae
  OS Version:   6.0.6002.2.2.0.272.7
  Locale ID:   1031
  Additional Information 1:   fd00
  Additional Information 2:   ea6f5fe8924aaa756324d57f87834160
  Additional Information 3:   fd00
  Additional Information 4:   ea6f5fe8924aaa756324d57f87834160
2.
Is there an obvious reason, why I canīt use Quad ARC Prediction with redbook files? The same is true for 24/176,4 native audiofiles with no upsampling. Both result in some kind of 'stuttering'.
3.
How could I possibly improve my settings? Should I try to decrease latency?
Please find my setup below. Any comments appreciated.
Claus
Notebook HP 6730b, 2 GB RAM, Intel Core2 Duo P8400 2,27 GHz
Server 2008 SP2 32-bit engl
Texas Instruments IEEE 1394 Bus host controller
Driver Microsoft 6.0.6002.18005 (21 Jun 2006)
RME Fireface 400
Driver 2.9.991.0 (11 Dec 2009)
Buffer Size (Latency) 1.024 Samples
XXHE 0.9y-5-06
Q1=2 (Distortion at Q1=1)
Q2/3/4/5=0/0/0/0
Device = KS: Fireface 400 SPDIF >> #hdspfirewave5
Engine 4
Unattended
Split File at Size 50 MB
Stop Services
"X3PB-20100214-200520.log" says "Normal Mode !"
Plays with no upsampling:
24/96 Audiofile in FLAC-Format
Redbook Audiofile in WAV- and FLAC-Format
Single Track from redbook large wavefile with cuefile
Plays with Double ARC Prediction
Asus M2A-VM HDMI - AMD Athlon 64 X2 Dual Core 4800+ - 2 x 1 GB DDR2 800 MHz - Windows 7 Pro SP1 x64 - OS/XX on SATA II 7200 rpm - Redbook WAV on same HDD - XXHE 0.9z-5-2 (unactivated) - Scheme=nothing - Engine#4 - Adaptive Mode - Q1/2/3/4/5=1/0/0/0/0 - Device Buffer=256 - No Invert - PlayerPrio=Low - ThreadPrio=Realtime - Unattended - Desktop Services Off - No Running Time - Quad Arc Prediction - ClockRes=Max - Split File Size=12/Straight Contiguous - Firewire - RME Fireface 400 (FW 1.70, Driver 3.047) - Headphones AKG K 340
« Reply #1 on: February 15, 2010, 09:48:54 am »
Hi Claus,
The Alt-n doesn't work because of a bug since the support for KS. I coincidentally solved that day before yesterday, and will be in the next version.
Can you please post your other issues in a separate topic ? I really don't want to confuse things, and want to be able to find them back later. And if you're at it anyway, explain more about your "suttering" and what you play and how (in that new topic).
Thanks !
claus
« Reply #2 on: February 16, 2010, 08:39:00 pm »
Thatīs good news. Thanks a lot.
Of course I will open a new topic. Sorry, didnīt want to confuse anybody. Actually I was searching for an existing topic my issues would fit in, but didnīt find any appropriate.
Claus
Page created in 0.12 seconds with 19 queries.
