November 23, 2024, 11:05:41 pm *
Author Topic: Can 16/44.1 files be upsampled to 24/192 using AP?  (Read 8894 times)
« on: February 15, 2010, 04:33:35 am »
I have a strange situation where my my Overdrive DAC does not support 176.4. My native files are 16/44.1; if I use QAP (my soundcard is 24 bit Off Ramp) then my output files from XXHE would be 24/176.4, which is supported by the soundcard but not by the DAC. Is there a way I could upsample my native files to 24/192 through XXHE?
« Reply #1 on: February 15, 2010, 09:28:07 am »
I asked the same question a few months ago and the short answer is no. Upsampling must be integer (2x, 4x, 8x).
guytou1
« Reply #2 on: February 17, 2010, 08:57:51 am »
Hello
Since the prefered sampling rate of my DAC is 96kHz I do often an "offline" conversion (saving the output file on flash memory) with foobar and the "Secret Rabit Code" sample rate converter. So, there is some preparation before a listening session...
« Reply #3 on: February 17, 2010, 09:58:52 am »
It is also possible while ripping, to upsample to say 16/48 & then QAP using XXHE; but I am very skeptical of the quality of the upsampler while ripping. I use dBpoweramp as the ripping software; does anyone know about their upsampler quality?
« Reply #4 on: February 17, 2010, 11:45:23 am »
Ok, I couldn't stand this. no
Here you go, up and running here, in the next version for you :
(but not for AP !)
guytou1
« Reply #5 on: February 18, 2010, 09:56:15 am »
Good news ! Happy
Page created in 0.34 seconds with 19 queries.
