April 07, 2025, 01:51:00 am *
Pages: 1 2 3 4 5 [6]  All
Author Topic: XXHIGHEND-M2TECH-WIN XP  (Read 86254 times)
« Reply #75 on: April 24, 2010, 10:01:31 pm »
So?
wimck
« Reply #76 on: April 24, 2010, 10:55:45 pm »
So.......if the Hiface doesn't work on a AMD system you can try a PCI to USB with that NEC chip
Windows 7 Ultimate 64bit SP1 and XXHighEnd on SSD - music on spinning disk @SATAII - Athlon II dual core 2,9Ghz - Engine#4 -Adaptive Mode - Q1/2/3/4/5 = 1/0/0/0/0 - Buffer 1024 - MIxed Contiguous - SFS 20 - Playerprio Low - ThreadPrio Real Time - All Services Off
PC -> M2Tech EVO -> 10 m Canare digiflex Gold II -> TagMcLaren AV192 / 2x250MR -> VS Unifield3 -> my ears
« Reply #77 on: April 24, 2010, 11:12:52 pm »
So?
Like 'Do YOU have an AMD PC'.
I thought you had a problem, so that's why I asked you...
(en die mail heeft durob van mij gekregen  Wink )
wimck
« Reply #78 on: April 25, 2010, 09:17:56 am »
sorry GerardA!
Yes I have a new AMD system, Athlon II X2 240e on a GA-MA785GMT-UD2H mobo.
Hopefully that USB card will solve my problem too.
Thanks for your card testings and sending it to durob!!
wimck
« Reply #79 on: April 25, 2010, 09:22:08 am »
Hi Peter!
See attached logfile
Thanks!
* X3PB-20100424-191107.log (0.65 KB - downloaded 586 times.)
« Reply #80 on: April 25, 2010, 10:18:50 am »
Hi Wim,
Can you please try below driver ? This one works here (XP) ...
So if this doesn't work either, it at least eliminates one variable (the driver).
But post the new X3PB log file again if it doesn't work !
* HiFace_XP_W2003_103141.zip (954.25 KB - downloaded 545 times.)
wimck
« Reply #81 on: April 25, 2010, 10:44:39 am »
That's the driver I already use!
I installed it again and the logfile is attached again.
One more detail, the system is freezing after a few seconds when started up with the Hiface connected.
Now we know it's not the driver, it has to be the USB support.
I ordered the NEC PCI card so next week we'll see
* X3PB-20100425-110036.log (0.65 KB - downloaded 1021 times.)
« Reply #82 on: April 25, 2010, 11:00:33 am »
Ok.
I don't think it matters, but you can try DAC Needs = 24 bits for the Hiface just the same (it can take both 32 and 24 bits).
wimck
« Reply #83 on: May 01, 2010, 12:16:42 pm »
An hour ago the PCI to USB (with NEC chip) card arrived. Putted it in and.........all is working again!  clapping
I also received a mail from M2Tech last week, they are working on a new driver which should solve the AMD SB700/710 problem.
I have listened to the TRENDS last week and again the better sound of the Hiface is very notable.
Thanks all for helping me!!
« Reply #84 on: May 01, 2010, 12:33:05 pm »
Good Wim ! And thanks for sharing.
