« Reply #60 on: February 22, 2010, 11:39:37 am » |
I used Engine#4, but it doesn't say much I guess (because I never tried #3).
« Reply #61 on: February 22, 2010, 11:53:39 am » |
Peter, Does your fireface work with engine4 special mode? I think it's quite similar to the terratec (same Envy-chip).
Then does AMD (quadcore) work with engine 4 special mode? I think core-appointment is not really working the same (?). Seems there can be a problem with AMD-chipsets and Hiface too... (asynchronus USB-mode not properly supported)
Anybody?
ivo
« Reply #62 on: February 22, 2010, 11:59:49 am » |
Then does AMD (quadcore) work with engine 4 special mode? Gerard, I have a laptop with AMD Athlon Dual core and special mode works with my built in USB DAC nicely. I did sniff USB yesterday and it runs in ISOchronous mode, but I cannot say which ISO type it runs in (adaptive,async or sync). As I do not see any bits for ISO type, I believe there is no sync mode at all deplyed which is actually bad, BUT on my system all works great even NOT having async USB device. However, I am planning to buy HiFAce too and as I have AMD laptop, this makes me worry now... Ivo
« Reply #63 on: February 22, 2010, 12:27:52 pm » |
It will work, but because you lack the Core Appointment stuff you won't be able to tune it right (or not optimally the least). So, Peter, what did you find were the best core appointment settings? Hey Gonz, the way things are going, I think the answer to your last question is Hiface, engine 4, special mode. At this point I haven't seen anyone who says that they prefer engine 3 over 4. Of course now that I've said this someone will surely show up...... Hey All, have a great day.
gonz
HIFI GEEK
« Reply #64 on: February 22, 2010, 12:41:59 pm » |
It will work, but because you lack the Core Appointment stuff you won't be able to tune it right (or not optimally the least). So, Peter, what did you find were the best core appointment settings? Hey Gonz, the way things are going, I think the answer to your last question is Hiface, engine 4, special mode. At this point I haven't seen anyone who says that they prefer engine 3 over 4. Of course now that I've said this someone will surely show up...... Hey All, have a great day. Thanks I`ll try engine 4 in special mode !
IBM Thinkpad T41 / WIN 7 Ultimate/M2TECH USB/SPDIF device/ACCUPHASE DAC inside DP-67/Interconnect RCA Bertram Ref silver lasertech/Accuphase E-406V intg. amp/Yter silver speakercables/Holfi Thyra Charisma MKII speakers.
gonz
HIFI GEEK
« Reply #65 on: February 22, 2010, 01:04:50 pm » |
I, ve started a new topic XXHIGHEND-M2TECH-WIN7 ,just to avoid misunderstandings with regard to what OS this is about ! Since I`ve converted to WIN 7 instead of XP
ivo
« Reply #66 on: March 24, 2010, 11:49:14 pm » |
Yes! Can confirm that HiFace does not work on my HP laptop (AMD) based. Most probably because of poor async USB support.  I did wrote about this problem to m2tech, but I guess they will not help me no way. Sad, will have to switch to another machine. Very sad.
« Reply #67 on: March 25, 2010, 09:05:33 am » |
Hi Ivo,
What defines "poor async USB support" ? Is that the AMD (if possible at all) ? I mean, on my XP machine it just works (which coincidentally is a HP, but not a laptop).
« Reply #68 on: March 25, 2010, 09:57:49 am » |
Hi Ivo,
I received my PCIe to USB3 card (Freecom) yesterday and now the Hiface installs properly on my AMD (SB700). But no sound! In sounddevices the hiFace shows, but test does not work and samplerates are not shown.
XXHE says in engine #4: 'Device allocated, but can not play...' in engine #3: '... not supported'.
I sent an email to Marco and he replied today that he will send it to his programmer.
If you see how much work they put in Mac-support I'm sure they will solve this problem too!
wimck
« Reply #69 on: April 24, 2010, 01:52:56 pm » |
Hi all! I have a problem with my HIFACE. I had it perfectly working on my too slow PC. Builded a new one and installed the recommended driver for HIFACE. In XXhighend it is in the device box as KS, Hiface Kernel Streaming... but when I push play I have a message telling me " Device allocated but can't play;check DAC settings, applied sample reat etc." I tried all settings I think but nothing work!
When using my TRENDS it works fine.
anybody who can help me with this problem?
Windows 7 Ultimate 64bit SP1 and XXHighEnd on SSD - music on spinning disk @SATAII - Athlon II dual core 2,9Ghz - Engine#4 -Adaptive Mode - Q1/2/3/4/5 = 1/0/0/0/0 - Buffer 1024 - MIxed Contiguous - SFS 20 - Playerprio Low - ThreadPrio Real Time - All Services Off
PC -> M2Tech EVO -> 10 m Canare digiflex Gold II -> TagMcLaren AV192 / 2x250MR -> VS Unifield3 -> my ears
« Reply #70 on: April 24, 2010, 02:21:01 pm » |
With the notice this topic is about XP (and the HiFace), what happens when you try Engine#3 ? (please list all the messages coming forward) Try this right after a reboot.
Also, what files are you playing (16/44.1 etc.) and what are your upsampling settings ?
wimck
« Reply #71 on: April 24, 2010, 03:42:01 pm » |
I am using XP and can't choose another engine. The engine 4 field is grey. When starting the PC and XXhighend there's a message after a while " engine 4 did not start within the expected time" The DAC is found. I use adaptive mode, device buffer 2048. No upsampling, DAC is 24 bit/ 192 khz, DAC needs 32 bit . No core appointments.
The I try to play are normal wav's or flac's ripped on 16/44.1
« Reply #72 on: April 24, 2010, 04:15:39 pm » |
It's not BTW an AMD?
« Reply #73 on: April 24, 2010, 05:47:39 pm » |
Well Wim, nothing else left than to post your X3PB log file. Play a normal 16/44.1, not upsampled or anything.
wimck
« Reply #74 on: April 24, 2010, 08:34:25 pm » |
There seem to be problems with the USB support from AMD chipset. Got a mail from the HIFACE importer in Holland.
" It functions now with a PCI to USB2 card with NEC chip!! With XXHighend-player the results are very impressive. Other cards did not work:
USB from AMD-chipset: No PCIe to USB3 (Nec) : No PCI to USB2 (Via) : Yes, but very high distortion.
