gonz
HIFI GEEK
« Reply #45 on: February 19, 2010, 03:06:36 pm » |
Actually I like XMPLay better than Foobar if we talk about WASAPI path. But XX beats both. XMPlay and Foobar are more sharp and colder than XX therefore I myself consider XX as better. Also XX has better pronounced bass, I would say it is more intelligent than XM's or Foobar's.
In my opinion the XXHIGHEND almost sounds high end, all the other software-players don`t ! I totally agree with the fact, that the bass is much better pronounced and the high frequencies are so much smoother, though still very detailed and airy !
IBM Thinkpad T41 / WIN 7 Ultimate/M2TECH USB/SPDIF device/ACCUPHASE DAC inside DP-67/Interconnect RCA Bertram Ref silver lasertech/Accuphase E-406V intg. amp/Yter silver speakercables/Holfi Thyra Charisma MKII speakers.
jkeny
« Reply #46 on: February 19, 2010, 03:12:41 pm » |
You don't have to open files through cmp. Click "explore", install JRiver Media CEnter and set for external software -> cPlay. This is the best combo in terms of SQ and convenience, period. Hi Marcin  , we have been spoken already. How does the this work in practise though - is it fairly seamless or does it jump back & forth between JRiver & Cplay i.e can cplay run in the background & play the files while JRiver remains as the GUI? I've tried setting different external players in MP3Toys (my favoured GUI) but this is the way it operates! PS I suggest you run DPC Latency checker at your machines and write it here. Mine shows constant 2-3 us.
On my stock laptop, I get something like 230us normally but a whopping 21,000 when WAN is active
gonz
HIFI GEEK
« Reply #47 on: February 20, 2010, 08:54:00 pm » |
Well now IŽve really done it  Infected my own thread  I have installed WIN 7 Ultimate on my CPU instead of XP PRO and now XXhighend and M2TECH works a lot better no more sudden blue screens og reboots ! Now everything that is available in the demoversion seems to work flawlessly NICE  What would be the ultimate settings for the Engine3 / Win7 / M2TECH ??????
jkeny
« Reply #48 on: February 20, 2010, 09:21:30 pm » |
Very nice, gonz, I want to install Win 7 but don't have the external disk space to backup my data before install
ivo
« Reply #49 on: February 20, 2010, 11:44:45 pm » |
Hey gonz,
How about VISTA? Have you tried it there?
Ivo
gonz
HIFI GEEK
« Reply #50 on: February 21, 2010, 02:27:12 am » |
Hey gonz,
Ivo
Nope VISTA is completely banned on my CPU
« Reply #51 on: February 21, 2010, 10:39:01 pm » |
Hey Gonz, any chance you've gotten into special mode with Hiface and 9y-6 (if its even possible)? Just wondering how it sounds.
gonz
HIFI GEEK
« Reply #52 on: February 21, 2010, 11:25:37 pm » |
I don`t know if the special mode works in the demo version  But you`d better ask Peter !
« Last Edit: February 22, 2010, 09:45:43 am by gonz »
gonz
HIFI GEEK
« Reply #53 on: February 22, 2010, 09:46:57 am » |
The special mode works on engine 4, but not on engine 3 on my CPU !!
« Reply #54 on: February 22, 2010, 10:10:48 am » |
Special Mode is for Engine#4 only. The demo version *does* indeed matter; It will work, but because you lack the Core Appointment stuff you won't be able to tune it right (or not optimally the least).
gonz
HIFI GEEK
« Reply #55 on: February 22, 2010, 10:36:01 am » |
Thanks for the info  Obviously there`s a difference between the demo and the undemo , this is as it should be !  Peter what is your opinion about the sound quality using the M2TECH versus a firewire solution ??
gonz
HIFI GEEK
« Reply #56 on: February 22, 2010, 10:40:37 am » |
Does this mean that the special mode will not work with the M2TECH ??
« Reply #57 on: February 22, 2010, 10:44:31 am » |
Huh ? What makes you think this ?
Anyway, it works perfectly with the M2Tech/HiFace (I tried it).
« Reply #58 on: February 22, 2010, 10:52:17 am » |
Peter what is your opinion about the sound quality using the M2TECH versus a firewire solution ?? From what I have heard of it ... better. I used it to feed my Fireface800 via SPDIF, and I was quite surprised how good that sounded. Normally the Fireface is fed by Firewire, and I've always found that sounds "so-so". Notice that I have no real means of comparing to what I'm used to, because my own Phasure NOS1 uses a "better" connection  , meaning that feeding it with SPDIF would incur for two additional conversions compared to what I'm used to. That never is good. Nobody buying a HiFace will be sorry I think. But of course you first must have a need for it. Peter
gonz
HIFI GEEK
« Reply #59 on: February 22, 2010, 11:36:10 am » |
Peter what is your opinion about the sound quality using the M2TECH versus a firewire solution ?? From what I have heard of it ... better. I used it to feed my Fireface800 via SPDIF, and I was quite surprised how good that sounded. Normally the Fireface is fed by Firewire, and I've always found that sounds "so-so". Notice that I have no real means of comparing to what I'm used to, because my own Phasure NOS1 uses a "better" connection  , meaning that feeding it with SPDIF would incur for two additional conversions compared to what I'm used to. That never is good. Nobody buying a HiFace will be sorry I think. But of course you first must have a need for it. Peter Ok IŽll be doing some testing the next couple of weeks ,comparing the M2TECH versus Firewire using a RME Fireface 400 as DAC !! Which engine should I use with the M2TECH for best sound quality ??
