April 06, 2025, 06:25:58 am *
Pages: 1 2 [3] 4 5 6  All
Author Topic: XXHIGHEND-M2TECH-WIN XP  (Read 86249 times)
« Reply #30 on: February 18, 2010, 01:37:53 pm »
Hi Ivo, I am able to play 24/96 files, engine 4, 9y-5-06.
ivo
Music lover
View Profile WWW
« Reply #31 on: February 18, 2010, 01:40:51 pm »
Using HiFace?
Anyway I guess you have *DAC is* set to 32 bits, ah?
Ivo
« Reply #32 on: February 18, 2010, 01:42:23 pm »
Right, no hiface and dac set to 32 bits.
ivo
Music lover
View Profile WWW
« Reply #33 on: February 18, 2010, 01:43:37 pm »
Yeah Happy
The summary was ment for HiFace device. I also can run DAP and QAP with engine#4 with my AudioTrak Prodigy HD2.
Ivo
gonz
HIFI GEEK
« Reply #34 on: February 18, 2010, 02:16:53 pm »
Yeah Happy
Ivo
Yep  Cool
Lets stay with the topic XXHIGHEND / M2TECH
IBM Thinkpad T41 / WIN 7 Ultimate/M2TECH USB/SPDIF device/ACCUPHASE DAC inside DP-67/Interconnect RCA Bertram Ref silver lasertech/Accuphase E-406V intg. amp/Yter silver speakercables/Holfi Thyra Charisma MKII speakers.
« Reply #35 on: February 18, 2010, 04:56:59 pm »
Okay, so when are you guys going to let us know how XX sound via Hiface? Am presuming its very good.  ok
gonz
HIFI GEEK
« Reply #36 on: February 19, 2010, 12:00:49 pm »
Sounds  sounds good !
jkeny
« Reply #37 on: February 19, 2010, 12:12:06 pm »
It sounds smoother than Foobar V1.0 but I don't know yet if this is a good or bad - I'm listening through headphones & need to hear it on a full rig. I'll be bringing my HiFace + laptop to an audio meeting on Saturday & I'll be auditioning it more fully then. I will report back on the consensus opinion.
Also, I'm a bit concerned - I've had a number of Blue Screens of Death showing VADSPDIF.SYS as the driver problem - this is a HiFace driver & I'm wondering if it's flaky? It only seems to happen when running XX though.
I've also noticed, when running Foobar or other music players, that sometimes there's a drop-out in sound for a second in the music - have you noticed this gonz?
ivo
Music lover
View Profile WWW
« Reply #38 on: February 19, 2010, 12:19:11 pm »
You mean XX+HiFace is smoother than Foobar+HiFace?
jkeny
« Reply #39 on: February 19, 2010, 12:22:59 pm »
Yes, that's exactly it. Normally I would rate smoother as better but I need to listen on a good rig to be sure Happy
ivo
Music lover
View Profile WWW
« Reply #40 on: February 19, 2010, 12:27:33 pm »
Actually I like XMPLay better than Foobar if we talk about WASAPI path. But XX beats both. XMPlay and Foobar are more sharp and colder than XX therefore I myself consider XX as better. Also XX has better pronounced bass, I would say it is more intelligent than XM's or Foobar's.
jkeny
« Reply #41 on: February 19, 2010, 12:38:35 pm »
Yes, I'm also trying to listen to CPlay but the CUE sheets are killing me. I haven't noticed the more pronounced bass with XX, in fact I might have said the opposite but again I'm only listening through headphones & all their limitations.
You don't have any drop-out problems with the latest HiFace drivers then? It might be my laptop which is flaky & I've been threatening to switch to WIn7 but don't have external disk space for a backup!
Edit: Oh, just realised XMplay is different to CPlay, doh!
ivo
Music lover
View Profile WWW
« Reply #42 on: February 19, 2010, 12:51:57 pm »
No, no, no. I do not have HiFace yet at all. My comparisons are based on my current gear which is laptop+quick dock with spdif out. I am preparing myself to order HiFace. But actually, the relations among Foo/XM/XX will remain anyways I guess. Yes, CPlay with its crazy cue sheets is also killing me, but its sound is interesting - I tried to upsample from 44 --> 192 and it actually beats XX to my mind in terms of dynamics. The shortage of CPlay is that it has the overall sound sig moved a bit up - less bass and more highs if compared to XX. I do not know what is better so far. Actually, I do not know why XX is limited to 88 and 176 kHz upsampling and not allowing to do 192.
Marcin_gps
« Reply #43 on: February 19, 2010, 02:43:41 pm »
You don't have to open files through cmp. Click "explore", install JRiver Media CEnter and set for external software -> cPlay. This is the best combo in terms of SQ and convenience, period.
PS
I suggest you run DPC Latency checker at your machines and write it here. Mine shows constant 2-3 us.
gonz
HIFI GEEK
« Reply #44 on: February 19, 2010, 03:00:38 pm »
I also had the bluescreen and shutdown problems with XXHIGHEND / M2TECH, but after reinstalling both XXHIGH and the M2TECH drivers it`s been far more stable ! I`ve have no experience with the Foobar problems you mention cause I don`t have Foobar on my PC ! A freind of mine use the Foobar software and I use his machine to compare the sound quality ! I don`think that Foobar sounds better that Win Media Player !
I await Peter`s feedback, when he has had a chance to fool around with the M2TECH himself ! Maybe he can solve our small problems ( hopefully )  Happy
Maybe the full version of XXHIGHEND works better in this case ???
