November 23, 2024, 10:43:32 pm *
Author Topic: KS with q1=-1 locks my computer  (Read 7164 times)
« on: February 14, 2010, 01:21:06 am »
the main one, with the x-fi
it becomes totally unresponding, while the music flows. the only fix is to power off (reset isnt enough).
very, very weird.
« Reply #1 on: February 14, 2010, 07:33:00 am »
very, very weird.
You're not alone in your observations ...
http://www.phasure.com/index.php?topic=1096.msg9366#msg9366
« Reply #2 on: February 14, 2010, 08:18:46 am »
If you know what to look for, you can see this is driver behaviour. Here is an example of it without further explanation : Re: 0.9y-5-05.
Although I am very sorry these things happen, please notice that we are "asking" for these kind of problems. And yes, of course I urge you to it.
The least you can do (at trying Q1 values) is not setting the thread priority so high. It may help. Once you found a good setting, yuo can set the priority back.
The next version should be more "under control".
« Reply #3 on: February 14, 2010, 12:18:23 pm »
It's ok, Peter.
I knew it were the drivers, creative is known for sh*tty drivers. It's the need for a cold power up that scared me.
I used the same settings as GerardA (Q1 = 11, Q2,3=18, Q3,4=0, KS) before without any issue. Those settings are my favourite with the x-fi.
Page created in 0.122 seconds with 19 queries.
