November 23, 2024, 10:41:13 pm *
Author Topic: Lynx AES 16 KS errors on XP 0.9y-5-05  (Read 25917 times)
minzyman
« Reply #15 on: December 02, 2010, 06:35:55 pm »
Thanks Robin Hood.
Was able to get XXHighEnd to work simply by installing a new Lynx driver, 18C actually, although I will upgrade the OS to Win 7. Engine #4 is now working and sounding very good I might add. Far better than MediaMonkey. They would do well to license use of the engine from Peter. Sound is smooth like Sequioa Samplitude, which I tried awhile back for sonics. Getting decent soundstage, detailed lowend.
Would be nice to see a better interface, although I know this takes time. I am still having issues with the app crashing after playing 6-8 songs. Also, cannot get my Alpha Dac to register sample rates other than 44khz on the front LED. On 24/96k and up tracks, some will play but no 24bit flag is passed on to the dac.
I will keep playing and will post more as I discover solutions.
Thanks guys for the help.
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
« Reply #16 on: December 02, 2010, 07:02:05 pm »
So simple eh ? well, good !
The obvious question now : You did set DacIs to 24/192, right ?
PS: Shouldn't you stay with XP for a while ? Nobody (so far) says it bad or worse that Vista. About all say W7 is worse than anything else ... yes
minzyman
« Reply #17 on: December 04, 2010, 12:26:21 am »
I suppose I should stick with XP if that is the case. I was planning on reading about W7 this weekend on the forum.
Yes, I have the Dac set to 24/192. Anything else I might consider changing/tweaking?
Darned! It just crashed again.
/Lee
« Reply #18 on: December 04, 2010, 06:00:44 am »
About the crashing ... Do you have your Virtual Memory On ? (you should)
And what do you use for SFS.ini setting ? (that is a file in your XX folder; if you didn't touch it it will be 11).
Generally, I would lower your SFS (Split File Size) setting. Suppose it is 100 now, make it 80 or so. Or even lower.
Isn't that 192 not working something about another driver ? ... which maybe is available for Engine#3 only ?
I recall something like that. Someone with a similar or even same problem in here (Alpha and AES).
minzyman
« Reply #19 on: December 05, 2010, 06:15:57 am »
Virtual memory was already on, 2045MB
SFS.ini already set to 11
split level size was at 60, now at 80.
I am finding that the program will just crash on its own, while playing or not. Usually happens after 3 or 4 songs have played, but will also crash when idling (no song playing).
I am using an OCZ Vertex SS drive, 120Gig.
/Lee
« Reply #20 on: December 05, 2010, 09:42:52 am »
Aaarrrrggghhh ...
Uhm Lee, that is the demo version you are using. It stops between 6 and 60 minutes ...
Happy Happy Happy
minzyman
« Reply #21 on: December 05, 2010, 11:44:57 pm »
You mean the program randomly shuts off (crashes) between 6 and 60 minutes?
I don't remember reading anywhere about this...
« Reply #22 on: December 06, 2010, 05:48:50 am »
Dear Lee,
From Demo version, Install notes and getting an Activation Key :
What you download from this board (the XXHighEnd-x.xx.zip files)  is a fully working demo version, only limited in playing time per session; When you've got an Activation Key your demo version will have turned into a normal licensed version for your household with unlimited playing time.
But I'll admit that the 6 and 60 was not mentioned there. I added it in that text and put it in bold in the mean time.
I apologize for the confusement !
Now, let's see what's up with the 192KHz ? Or do you have that going already ?
