April 05, 2025, 06:34:18 am *
Pages: 1 2 3 [4]  All
Author Topic: 9Y-5-06 special mode  (Read 52277 times)
« Reply #45 on: February 17, 2010, 04:54:29 pm »
I agree Ivo. With engine 3 all music sounds better with AP. Engine 4 is where I find that classical or more complex music is better with all upsampling in XX turned off. Vocals or less complex music, such as Julian Bream and John Williams, Together and Together Again recordings, sound best with AP turned on (engine 4). Will be interested to hear what you find when you start using engine 4.
« Reply #46 on: February 17, 2010, 05:42:18 pm »
hey there Peter,
a quick question about the contents of a typical X3PB log I have here ( see below ). In my setting I have chosen the CH34 ( digital ) entry from those available, and the log seems to indicate that it found it OK, yet a following line indicates XXHE is using the CH1234 output, which as far as I understand, is the combined analogue and digital entry.
Is this just a quirk of the drivers perhaps? The output comes from the SPDIF, so in that regard everything seems to be working as expected.
thanks,
=======  SNIP   =========
-07 (Stream Status)
-09
Start KS here
Name wanted  : Juli@ Ch34 >> #esi_wave2  Number of KS devices found : 3
Filter found : \\?\esi#julia_01#5&69f9183&3&01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\esi_wave1
Name attempt : Juli@ Ch12
Filter found : \\?\esi#julia_01#5&69f9183&3&01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\esi_wave2
Name attempt : Juli@ Ch34 ** Found ** ** Succeeded ! **
Filter found : \\?\esi#julia_01#5&69f9183&3&01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\esi_wave3
Name attempt : Juli@ Ch1234
No ambiguous devices found.
Filter used : \\?\esi#julia_01#5&69f9183&3&01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\esi_wave3
-13
-14
-15
-16
Works (half of total buffer size) : 50000000
Half of total buffer size : 50000000
Is infinite : 50000000
Used : 3525
-17
-18
-19
-28
-29 (Start Playback)
Special Mode ! (which is actually WRONG)
Wait for file to arrive (1) : 141
Wait for file to arrive (1) : 168
* X3PB-20100218-011639.log (1.91 KB - downloaded 598 times.)
« Reply #47 on: February 17, 2010, 06:51:04 pm »
Russ, good observation !
The last line shown just shows the last line examined. It's actually old log data, while in a before version the iteration stopped once the filter to use was found. This was changed into showing them all for your information. *This* by itself is actually overruled now by the list of devices which just shows in XXHighEnd.
I removed that line.
(and all was fine for the actual choice !)
