April 05, 2025, 06:51:56 am *
Pages: 1 2 [3] 4  All
Author Topic: 9Y-5-06 special mode  (Read 52279 times)
Marcin_gps
« Reply #30 on: February 14, 2010, 11:35:35 am »
I can't get special mode with my M-Audio Transit (USB, TAS1020B). The lowest Q1 setting without cracks is at 3. Also I can't play KS/WASAPI at 24/96, but that's in every player - M-Audio drivers suck!
« Reply #31 on: February 14, 2010, 11:37:26 am »
Notice it may be USB allowing for this.
No, wrong (I think); it will be your 8 times lower byte rate (because I calculate with 32/176.4 while you do 16/44.1). yes
« Reply #32 on: February 15, 2010, 04:12:52 am »
Thanks Peter. Had to change my signature again. Kernel Streaming  is unbelievable.
earflappin
« Reply #33 on: February 15, 2010, 04:41:35 am »
I agree the kernel streaming special mode in the latest XXHE release is superb and a very audible improvement over the previous version.  I presume a large part of the improvement is due to reducing latency?  I'm using a Lynx AES16 card.....is anyone using an async USB or firewire interface with XXHE and, if so, are you getting an incremental improvement with KS?  I would think not since I presume a properly implemented async interface should make latency a non-issue?
Peter, how goes it with your NOS DAC????
Marcin_gps
« Reply #34 on: February 16, 2010, 02:39:15 am »
OK, I switched to XP on other PC and it works just fine at 24/96 regardless output method.
PS
Q1 parameter at -4 sounds really bad on XP... Thin, flat, liveless, digital. I assume that dedicated server, just for music playback doesn't need any additional "latency corrections" or whatever Q1 is responsible for, only Peter knows. I prepared pure xp installation in nLite,  without most services and other "cr*p". It weighs only 100MB and is preoptimized. IMHO it is crucial NOT to install any other drivers but sound card. Once you install vga drivers you can forget about a decent sound. What I'm hearing now from my dedicated audio server is unbelieveable. XXHighEnd on w7 engine 3 or 4, doesn't play half as good as cMP². To be perfectly honest, everything else is really bad compared to cMP². Peter, keep working on "the timings"
Greets
« Reply #35 on: February 16, 2010, 03:16:10 am »
Gettin' lost here: For singer songwriter vocalists, Eva Cassidy, Patty Griffin, Jackson Browne, Dylan, James Taylor  etc., its kernel streaming with 2x arc prediction: they have never sounded so good. But for classical, (Bach violin concertos, Ann-Sophie Mutter) turn off arc prediction for the kind of precision and separation between instruments offered by engine 3. For Rock and roll, dunno, don't really listen to it that much, but I'd think no AP would be better.  wacko   Shocked  wacko
« Reply #36 on: February 16, 2010, 11:58:25 am »
Yes, i feel the same now (after many more hours). For piano pieces, i'm divided. Yesterday night I really enjoyed Chopin Etudes with KS.
« Reply #37 on: February 16, 2010, 12:21:26 pm »
.......and then, on the horizon , is special mode, whew..... heat But then, to have such quality and such choices, truly fucking amazing.
« Reply #38 on: February 16, 2010, 01:03:49 pm »
 Hey Telstar which recording of the Etudes are you listening to? Nelson Freire? Just wondering cause I haven't tried to "tune" in the piano yet. Happy
« Reply #39 on: February 16, 2010, 01:16:21 pm »
Nikita Magaloff (philips), Etudes op.0 and op.25.
« Reply #40 on: February 17, 2010, 01:19:58 pm »
Thanks Telstar, I haven't heard that recording. With the Freire recording, which isn't that great, no AP is best.
One thing I noticed last night was the "depth" of the sound stage that kernel streaming has brought. 9y--5-02, engine 3, now sounds flat or horizontal compared to the 3 dimensional sound of kernel streaming. Whats is amazing to me is that the depth isn't about "placement" but rather about a harmonic richness that's lacking in engine 3. (Being new to "great audio" I really don't know how to describe this stuff!)
ivo
Music lover
View Profile WWW
« Reply #41 on: February 17, 2010, 01:53:03 pm »
boleary,
When you mean the above, does it mean you use simple re-sampling without AP feature?
Ivo
« Reply #42 on: February 17, 2010, 01:54:12 pm »
Not so long ago I described this as "there is no such thing as depth", and the sound is just everywhere. So, it is (has become) difficult to pinpoint instruments in the depth direction. Whether this is (theoretically) good or not I'm not sure, but it makes you being inside of the music.
« Reply #43 on: February 17, 2010, 02:32:27 pm »
Hi Ivo. On the Freire recording I uncheck "double" which undoes all upsampling.
Dunno about "there is no such thing as depth". On vocals, especially, there's layers of richness that just weren't there before. It is GOOD, very, very GOOD! (Of course, to these ears on this system.....)
ivo
Music lover
View Profile WWW
« Reply #44 on: February 17, 2010, 03:09:06 pm »
Boleary,
When AP was introduced it was another method of upsampling compared to the *regular* so that is why I asked. Actually, my listening experience (so far with engine#3) says that it is better to use upsampling. Music gets closer, it gets spatial and more dynamic compared to raw 16/44. I guess higher-end standalone CDP all use some kind of upsampling.
I am waiting when engine#4 will work with HiFace then I will see which one is better for me: engine#3 in QAP OR engine#4 in QAP.
Ivo
