November 23, 2024, 11:25:06 am *
Author Topic: Feature request -- Preset buttons for different combinations of settings  (Read 4875 times)
« on: January 14, 2010, 12:27:49 pm »
Not sure which sub-forum this should go, so plonked it here.
Hey Peter,
would it be possible to have some user adjustable pre-defined "settings" buttons within easy clickable reach on one of the tabs, or even better, squeezed in on the left section somehow?
When swapping from redbook, to hires and also DTS encoded albums, it is necessary to toggle some of the settings/parameters. A little tedious at times as you might have discovered by now.
I'm thinking of perhaps 3 or 4 to cover likely scenarious and to allow the labels to be renamed as the user wishes, although I can imagine there would be a restriction as to how many characters each button would accommodate. Or perhaps label them from the onset as "RB" (redbook), "HR" ( Hi-Res), "DTS", and "USER".
In operation, you would alter the settings/parameters as required to playback the type of files, and then assign that mixture to one of the buttons. Then all it would take is a single click and your environment changes to suit file type.
For example, playing a 24bit hires would need the sampling disabled, or playing a DTS would need the crack detection disabled, etc.
Does this make sense ?
« Reply #1 on: January 14, 2010, 12:55:24 pm »
I've already planned such a thing for a long time ... about screen settings (panel sizes etc. in presets). But this is better !
Thank you Russ.
Page created in 0.125 seconds with 19 queries.
