November 23, 2024, 08:14:47 pm *
Author Topic: Will 9y-1 work for me.  (Read 8995 times)
Chris V
« on: January 13, 2010, 03:22:55 pm »
Hi Peter, long time no speak. Hope you're keeping well.
I have been playing the w version of XX for some time and been very happy, but I would like to upgrade now to 9y-4 if my gear will take it. One reason for not upgrading sooner is that I was getting a bit bemused by all the computing talk that accompanies the later changes. But, I have bitten the bullet and am ready for a new challenge.
I have got Autokeys running fine but cant easily find a list of all the functional keys. Can you help?
Most importantly I see you have various upsampling options and would like to try the well reviewed Quad if my system can take it.
I am still using the Fireface 400 which you know well and the Tact DAC which claims to have input sample rates up to 192KHz/24bits. Is this good to go?
Then to SW1X Signature DAC
« Reply #1 on: January 13, 2010, 05:20:43 pm »
Here ya go Chris. It's possibly missing a couple of the very latest shortcuts. Will amend later today after I've woken.
http://www.phasure.com/index.php?topic=939.msg7522#msg7522
 sleeping
« Reply #2 on: January 13, 2010, 05:30:02 pm »
I have a text file of most buttons, but not the latest changes !
Otherwise see "Edit this script"  or open in text-compiler to see all buttons
Hope this helps
Roy
* autohot.txt (1.02 KB - downloaded 530 times.)
Chris V
« Reply #3 on: January 13, 2010, 05:53:21 pm »
Thanks guys. There's a massive amount of info on this site now and a bit difficult to search around. wacko
I did find some by trial and error but having a list is good. good
« Reply #4 on: January 13, 2010, 11:39:58 pm »
Chris and others,
I've updated the listing of autohotkey shortcuts to include the Alt-Z entry for copying tracks to the "Demo" area in the gallery.
If you are uncertain whether that list contains the most uptodate shortcuts, you can always open up the XX.ahk file ( found in your XXHE folder ) with notepad ( or wordpad or similar ), and look towards the bottom where new entries will likely appear.
Note: for the Alt-Z to work, you will need to replace the XX.ahk file currently in your active AutoHotKey folder, with the one in the "install" of 0.9y-5-00
« Reply #5 on: January 14, 2010, 12:00:43 am »
Hi Chris - Just go for it. Don't fall into the "trap" of this Kernel Streaming; it will only demotivate you. This is for early adopters I guess, and even then ...
So, try 0.9y-4. Your Fireface and the TacT will dig it.
Your PC ? well, you know that better by now !!
