November 23, 2024, 06:12:42 pm *
Author Topic: Error message in XXHigh End 09y - 5-00  (Read 27413 times)
JoaquinM
« Reply #15 on: January 14, 2010, 07:25:56 pm »
Hello,
I am having a BIG trouble here with the 09y-5. I installed it this morning. When I was trying to select the music root (an external Iomega hard disk, USB connected), the program crashed. Now Windows doesn´t recognize that drive anymore! The same with a flash drive. It says they are USB unknwon devices. I have restarted the PC, uninstalled and reinstalled all the USB controllers, to no avail. This is serious trouble.
My computer is running Windows XP. I have run many previous versions of xxhighend before. None had this problem.
I need help!!
Joaquin
« Reply #16 on: January 14, 2010, 10:19:18 pm »
Hi Joaquin,
First of all, I'm approaching this as seriously as you do. So, this is not funny. But next ...
How in the worls can this be related to, say, me ??
Maybe good to know : I don't change one single bit to the Registry or enything else. And, the so-called "install" does nothing more than copying files.
In other words - what in Heavens name can have happened ? There is NO WAY I will be saying "not my fault", however, I can't imagine anything that would cause this to be my fault. Nothing.
Ok ... Now, with the above in mind, maybe you are "able to" think of something else ? The Iomega may break (especially the PSU). but how can that be related to another USB device ? I'd say Not. Can USB be broken in general ? maybe, but I have never heard of that. But maybe you have both behind an USB hub which broke down ? a too simple suggestion I guess.
So, just to keep in mind (please) : XX does nothing to anything. I'm puzzled.
mojave
« Reply #17 on: January 15, 2010, 12:49:35 am »
You might need to think about it the other way. Your USB controller on the motherboard might have failed. This prevented XXHighEnd from accessing the drive and the program crashed. You still can't use any USB devices because the controller is still bad. Do you connect the drive and devices to a front USB port on the computer? I have read that some of these are not grounded very well and with dry winter weather (at least where I live) you can get static electricity problems when you go to plug in a USB device.
« Reply #18 on: January 15, 2010, 12:55:40 am »
G'day Joaquin,
firstly, welcome to the forum, although I'm sure the circumstances of your first post could have been under better circumstances.
I suspect you have co-incidentally fallen victim to the all too common frailness of USB under WinXP.
Have a look here ( http://www.online-tech-tips.com/computer-tips/usb-device-not-recognized/ ) for one possible remedy, but rest assured, it is almost certainly a registry error that is causing that USB device to be ignored now.
If the above link doesn't cure your problem, start googling for something like "USB device unknown" , "fixing USB devices" or similar.
Some time ago I experienced a particularly troublesome glitch similar to what you are experiencing, and I bookmarked the solution, but unfortunately I can't find that link for you now. I'm sure you will find the solution with a little googling though.
It is a fact of life that early USB controllers and XP are not as rubost as they are today. Everyone will have a problem USB device at some time. If you are old enough to recall the introduction of USB to the world by Bill Gates himself, you will understand what I mean.
Best of luck at finding the solution.
« Reply #19 on: January 15, 2010, 01:00:26 am »
This is a possible cause also. Some of the earlier Intel chipsets were susceptible to physical USB controller failure caused by static discharges. It is important to always try and use the "clean" disconnect routine when dealing with USB devices. Simply unplugging an active USB is not ideal.
JoaquinM
« Reply #20 on: January 15, 2010, 12:02:46 pm »
Hello,
I have just tried Russ´ link (it recommends unplugging the PC), and it has worked! Thanks a lot!
Now I check if 9y5 is better for me than 9y4!
Joaquin
« Reply #21 on: January 15, 2010, 12:40:51 pm »
Isn't life full of wonderful surprises  grazy
Glad to read it all worked out.
Now .. go have fun !
huynh chau
« Reply #22 on: January 19, 2010, 02:57:38 am »
 I had problems with the xxHighend 09y - 5-00 version . I can't setting #4 Engine...
« Reply #23 on: January 19, 2010, 03:07:10 am »
What about the 0.9y-5-01 version ? -00 for sure hardly works for anyone !
(but it looks like out of memory, so if it persists with 5-01 try lowering the Split File size parameter (Settings Area, 60 should always be sufficient))
« Reply #24 on: January 20, 2010, 11:52:10 am »
5-02 is doing very well on my main PC. About 2h without an error!
