November 23, 2024, 04:53:57 pm *
Author Topic: Error message in XXHigh End 09y - 5-00  (Read 27398 times)
« on: January 12, 2010, 11:46:19 pm »
Every time when i start XX i get a error message. After 4 clicks this error message disappeared and the program starts. See attachment
« Last Edit: January 13, 2010, 06:29:51 pm by JohanZ » Logged
« Reply #1 on: January 12, 2010, 11:51:31 pm »
That is the same as your other post ... something wrong (and unexpected) with the Sound Devices ...
(http://www.phasure.com/index.php?topic=1049.msg8847#msg8847)
Not a nice message, I'll admit.
« Reply #2 on: January 13, 2010, 08:31:48 am »
Every time when i start XX i get a error message. After 3 clicks this error message disappeared and the program starts. See attachment
Just installed y-05 on my main pc (x-fi soundcard, w7 enterprise x64).
I get the same error message, and it requires 4 clicks to go away.
I changed the device din xxhe to x-fi from primary driver, but the message stays.
Tried engine3 and both no upsampling and 4x AP. All works the same.
Will try KS soon and update.
« Reply #3 on: January 13, 2010, 08:59:08 am »
Ok, something else must be going on. Both W7 Enterprise eh ?
Not everything is in there (I know) ... and in this case it is reflecting the Registry ...
Johan (but the question may count for Telstar just the same), do you recognize that you could only play Engine#3 via the Primary Sound Device ? (just in 0.9y-4)
This is not funny.
PS: I forgot why, but I did not get Enterprise (while a normal human being would have, when he had the chance). So whatever it is, you may be in lack of it anyway.
« Reply #4 on: January 13, 2010, 01:28:17 pm »
I dont understand the question  unhappy
« Reply #5 on: January 13, 2010, 01:30:56 pm »
Suppose you have 4 devices; the first one always shows as the Primary, but, the second one *is* that Primary.
Q: Could you ever play the 3rd or 4th device without changing the Primary Sound Device ?
« Reply #6 on: January 13, 2010, 01:36:31 pm »
I have only two devices, besides the primary one: xfi (analog) and xfi spdif. Both in control panel and in xxhe interface.
If changing names can help, how should i change them (sorry but it's not clear).
See attached pic.
« Reply #7 on: January 13, 2010, 05:00:46 pm »
I have those messages too ! (click 4 times to be gone)
But can it be so that #3Engine is better too!
I have something back I have missed, full firm bass, and all is controlled by amp better too.
So very big and controlled basses are back, I'am using same settings as before.
Did you changed (updated) anything.
It sounds way smoother then before, I dunno.
Roy
huynh chau
« Reply #8 on: January 13, 2010, 06:24:22 pm »
I thought xxHighend sounded nicer than Foobar, but I had problems with the xxHighend 09y - 5-00 version falling over periodically - after perhaps 30 to 60 minutes it was gone, no trace of it when checking what was running and I can't setting #4 Engine...
Per
Music is forever...
« Reply #9 on: January 13, 2010, 06:36:51 pm »
Hi Huynh - and welcome.
I would suggest that you install version 0.9y-4 and start from there. I am having different problems too with 0.9-y5-00. Use a new folder so that you do not mix up the two versions. Good luck.
Per
Sep 2010
« Reply #10 on: January 13, 2010, 06:40:38 pm »
  .....do you recognize that you could only play Engine#3 via the Primary Sound Device ? (just in 0.9y-4)
I can play Engine3 in 09-4: via Primary Sound Device and Speaker(Prodigy HD2)
« Reply #11 on: January 13, 2010, 11:51:37 pm »
G'day,
It's not running in 'demo' mode still is it? If it is, XXHE will simply disappear randomly between 10 and 30 or so minutes after startup.
« Reply #12 on: January 13, 2010, 11:56:53 pm »
Hi Johan,
Maybe it is not clear, but what you said is just what I suggested, because both are the same : the Primary Sound Device.
But what about the 3rd  (which actually is the 2nd) ? Can you ever use that with Engine#3 ?
« Reply #13 on: January 14, 2010, 09:54:14 am »
Hi Johan,
I just tried with my third of the list (spdif out) and it works. i dont have a dac to connect, but no error in xxhe.
Same config as above, version y-5. You need me to try with y-4 as well?
« Reply #14 on: January 14, 2010, 10:27:39 am »
Hey, thanks.
No, no need to try that. But something very strange must be going on.
Well, I guess it won't be important anymore when the next version is there (won't take all that long). There will be no reason for the errors suring startup, and the KS devices will be normally selectable - without hassle.
