November 23, 2024, 10:44:34 pm *
Author Topic: How do I upgrade to the new version?  (Read 7830 times)
DannyD
« on: January 12, 2010, 11:32:41 pm »
Sorry to be dense but I'm not sure how to upgrade to the new version.  I read I should cut and paste new files from the zip file.  Do I paste them into XXHighEnd-09-04.  Is that all I have to do?  Do I then change the name of the folder to reflect the new version?  Will the XX file still know where to go?
Thanks for your help.
« Reply #1 on: January 12, 2010, 11:39:10 pm »
You can do that Dan, but be sure to overwrite all the files. But, your 0.9y-4 will be lost then (but you can "reinstall" that in the same way of course).
If you follow this one a bit : Installation guide for Dummies (which is not explicitly about upgrading) you can see how things can be setup so that you can work with several versions next to eachother.
Take your time for the latter. You can (re)do that later.
DannyD
« Reply #2 on: January 13, 2010, 12:16:33 am »
I'm trying to roll back to the previous version, but the xx.ahk script is still pointing to the new folder.  How do I change that back?
Dan
« Reply #3 on: January 13, 2010, 12:22:24 am »
IIRC
1. Start XXHighEnd
2. Start AudoHotkey (again).
Then it points to the "current" XX version.
Let me know if it works. Otherwise I must do some digging.
(who always uses the same XX folder)
DannyD
« Reply #4 on: January 13, 2010, 12:36:54 am »
Thanks.  That did it.
« Reply #5 on: January 13, 2010, 12:37:59 am »
Great.
