November 23, 2024, 01:33:56 pm *
Author Topic: Installing Vista  (Read 18321 times)
« on: June 27, 2007, 01:23:03 pm »
On mine Audio PC I have installed Windows Xp on Partition C and XXHighEnd activated on Partition D. This afthernoon I want to migrade to Vista by cleaning Partition C and do a clean instal of Vista on that partition. Will keep XXHighEnd the activated status? If it changed to demo mode, what can I do .......?  Cool
Johan
« Reply #1 on: June 27, 2007, 01:36:53 pm »
First off, when it will turn out that it changed to demo mode I'll help you out no matter what. For the specific problem Bert had I found a solution, but it has to be programmed yet. Most probably tonight. BUT, this requieres this solution to run in advance of things, while your case might be an "afterwards" case because it kind of requires a "safety backup" to something you can't have (think of two PC's running, while you can't run both XP and Vista at the same time on the same PC).
Still I think the solution foreseen can manage, but then you should have it FIRST before you proceed with this migration.
Could you wait a bit ?
And not be disappointed when I bump into unexpected stuff and don't have it tonight ?
and be a testcase then ? grazy
« Reply #2 on: June 27, 2007, 01:57:22 pm »
Could you wait a bit ?..........................and be a testcase then...............
Ok, i'll wait........ Rules
« Reply #3 on: June 27, 2007, 02:59:59 pm »
Just a question Johan : would you have 2 PC's LAN connected ?
I'm not saying that you must create this situation (for now Happy. So it's just a question indeed.
« Reply #4 on: June 27, 2007, 03:32:30 pm »
Yes the Audio PC is temporarely connected to the LAN. When it is up and running it go's back to the Livingroom where I dont have a lan connection.
Johan
« Reply #5 on: June 27, 2007, 11:45:07 pm »
Johan, I just gave up in getting it done today. I'm sorry !!
« Reply #6 on: June 28, 2007, 01:08:08 am »
Good night.......zzzzzzzzzzzzzzzz. sleeping
« Reply #7 on: June 28, 2007, 07:44:27 am »
http://www.phasure.com/index.php?topic=110.0
innocent
« Reply #8 on: June 29, 2007, 12:16:21 am »
....at last Succeeded!
Hints:
Both PC's needs XX 0.9b
The "activation code" field needs to contain the path e.g. \\AUDIOPC\XXcurrentversion\
Don't forget the last back-slash! Push the <Activate>-button and restart XX and the job is done! heat rofl
Johan
« Reply #9 on: June 29, 2007, 12:26:51 am »
Hey Johan, very good !
One amendment : push the <Activate> button TWICE. Tongue
(once for the path reference, and once for the then obtained Code)
« Reply #10 on: June 29, 2007, 11:25:48 pm »
This afternoon I started to install Vista on mine Audio PC. After solving some troubles with drivers the system is now up and running incl.a LAN connection.
In mine attemp to get XXHighEnd running here some experiences:
The first thing I did was creating a shortcut on the desktop (I have a second partition with the XX software). After starting XX I got a complex error message.
The next step I did was making the Folder "XXCurrentversion" empty and reinstall XX 0.9b. Result still the same error message.
I installed DirectX and DotNet Framework 3.0 (I think not necessary in Vista). Result no error message anymore but a safety message of Microsoft. When I activate the button <uitvoeren>, it gives the message "XXHighEnd Demo" and belief it or not after activating the"<OK> button the Dialog box disappeared.......... and....... nothing happens. XXHighEnd don't start!  I don't see any task like XXHighEnd.exe in the Windows taskmanager.
Do you have some suggestions?......... grazy
Johan
« Reply #11 on: June 30, 2007, 12:00:58 am »
Okay ... let's try to work this out.
I must look at a few things first ...
« Reply #12 on: June 30, 2007, 12:17:59 am »
Sent you a PM Johan.
dbyrd1
« Reply #13 on: June 30, 2007, 07:10:44 pm »
Let me know when you have the software working better,
I prefer not to install software that needs drastic fixes at the
outset.
 db
« Reply #14 on: July 01, 2007, 05:09:58 pm »
 oops
Forgot to respond in this topic : if all is as expected, this is solved per version 0.9d.
