November 23, 2024, 05:24:35 am *
Pages: 1 2 3 4 5 [6]  All
Author Topic: Help with Kernel Streaming.  (Read 74870 times)
« Reply #75 on: January 15, 2010, 11:32:16 am »
Same issue on the music pc: win7 x64 Home Premium (i suspect engine 4 works only on ultimate!)
Telstar,
Did you find time to listen to 3#Engine, I think there is improvement there !
I cant really say, but i put y5 in a separate folder and i can compare.
« Reply #76 on: January 15, 2010, 03:18:18 pm »
Engine#4 works absolutely fine for me...
... for about 10 seconds... then no sound for a short while (depending on split file size)... then sound again for about 10 seconds... then no sound... etc
Reducing the split file size to 12MB helps, and there is sound all the time, but a lot of skipping going on. DPC shows massive spikes in latency (over 50ms!) coinciding exactly with a skip.
I have no issues with device selection and QAP 'works' too (but as described above).
« Reply #77 on: January 15, 2010, 03:51:54 pm »
Can you please set your Split file parameter to 60, and post a picture of your CPU graph (TaskManager), that set to the highest refresh speed ?
Try to capture the picture with (at least) two "completed spikes"; this will fit.
I assume you do this Unattendedly.
Thanks a lot !
PS: with QAP please.
DannyD
« Reply #78 on: January 15, 2010, 06:13:15 pm »
I still haven't had any luck getting engine 4 to work.  Has anyone had success with a Windows 7/Lynx AES16/Berkeley Audio combo?  I'm undoubtedly doing one (or several) things wrong.  I changed the name of the first playback device to Lynx_Output and now in XXHE it shows as Lynx_Output (Lynx AES16).  I still have to hit the OK button 16 time on the "Initialize  =19=" error box when I launch XXHE.  I still get the error "selected device not suitable for kernel streaming"
Will the next release of XXHE attempt to solve these problems?  If so, I'm happy to sit tight and enjoy version 09-y4.  If not, and I therefore need to resolve these problems myself, can anyone lend a hand?
Thanks for your thougts,
Dan
« Reply #79 on: January 15, 2010, 07:24:53 pm »
Hi Dan,
Sorry, at the moment you can't. This is related to those 19 error messages (one per device you normally have in there swoon).
I just finished the major part of something which will behave normal for the device selection, but I guess it is time for a first beer here now.
I'll finish it up first thing in the morning and add some additional log data for those having problems with playing (which comes after decent device selection). Don't wait up for it, although I estimate it won't take me all that long tomorrow.
If you, currently, are interested in 0.9y-5 and Engine#3, you can disable all your devices except for the one you want to use. That will bring you one error message at startup only. This doesn't harm playback (as the 19 messages do not).
Sorry for your (and everone's) troubles !
DannyD
« Reply #80 on: January 15, 2010, 07:38:08 pm »
No Problem, Peter.  Thanks for the reply.  I swear Engine 3 sounds better in y5 than in y4. I'm listening with no upsampling and all Qs at 0.  I don't even mind the 16 clicks!
