November 23, 2024, 05:26:21 am *
Pages: 1 2 3 [4] 5 6  All
Author Topic: Help with Kernel Streaming.  (Read 74871 times)
« Reply #45 on: January 13, 2010, 02:46:53 am »
Split file size at 50 to 20, I didn't go lower, caused XX to play but there was no sound. "Dac needs" was set at 24, 32 caused a crash. Scheme one was ticked, no appointment caused a crash. Engine #3 in 9y--5 sounds good.....going back to it now  Happy
jkeny
« Reply #46 on: January 13, 2010, 03:47:54 am »
So, you now have the HiFace working in Win 7 with XX - cool - does it sound good?
« Reply #47 on: January 13, 2010, 08:35:06 am »
Cant use KS on my x-fi (maybe with a driver update, which i'm NOT keen to do considering ho bugged creative drivers are).
Will stick on engine #3 on this pc.
« Reply #48 on: January 13, 2010, 09:08:12 am »
No appointment caused a crash ?? Btw, you people tend to call more things a crash than I do. Happy A reboot would be though, as is a "XXEngine3 stopped working" or "Runtime error". A message from the application, no. So, what actually happens ?
Anyway, I wonder whether this is repeatable.
John, as how I read it boleary doesn't have sound. Nice and quiet - also cool, but not intended here. no
« Reply #49 on: January 13, 2010, 10:55:50 am »
Question just now i had to rename again. It did not remember what i have put in yesterday.... Any idears?
Grtz
Leon
oosterom@msn.com
« Reply #50 on: January 13, 2010, 10:59:15 am »
Hi peter,
At first I had that message about ks not being supported. After fiddling around with the names as described earlier, I no longer had that message (se log file). The player starts to play ............... but no sound. If I choose for engine 3 I have sound again.
Is there anything I can try to do in order to let engine 4 produce sound on my system?
regards
Leon
* X3PB-20100113-104604.log (0.58 KB - downloaded 532 times.)
« Reply #51 on: January 13, 2010, 12:07:50 pm »
Grtz
That's not the way to win prizes Gerard !
hahaha, but I guess it is in the beginning of this topic ?
E-DSP WAVE [ccoo]
« Reply #52 on: January 13, 2010, 12:10:15 pm »
Morning. well a crash here is a crash: blue screen, white lettering and messages like: Windows must shut down Memory_Management or IRQL_Not_Less_Or_Equal. Other times I wasn't given messages, the computer just shut down. Attached are some log files of playing with no sound and crashes.
* XX-20100112-200131.log (36.44 KB - downloaded 511 times.)
* XX-20100112-201144.log (9.06 KB - downloaded 505 times.)
* XX-20100112-201301.log (6.75 KB - downloaded 513 times.)
* XX-20100112-201731.log (35.65 KB - downloaded 503 times.)
* XX-20100112-202959.log (11.13 KB - downloaded 528 times.)
« Reply #53 on: January 13, 2010, 12:15:24 pm »
John, in my first post when I said I switched to engine three and it sounded good, that meant I had to go back to the m-audio and not the highface for sound. Engine 3 is wasapi.
« Reply #54 on: January 13, 2010, 12:27:21 pm »
Yes, good morning there !
Can it be so that from those who you read that they got it working -which was via KS anyway IIRC- that this was via ASIO4ALL ?
No, I am not asking yo to try this, but it seriously looks like the native KS drivers from the HIFace just crash your system.
I may have forgotten ... but what happens with Foobar in your case (look for the "KS:" device) ?
« Reply #55 on: January 13, 2010, 12:34:32 pm »
In Media Monkey it works and the name of the device is: HIFACE Kernel Streaming. That's why in my first post with the screen shot I thought I had to get rid of the second line of the name, the sigmatel stuff. That device is for an sigmatel spdif connection that does not exist on my system, there is not an spdif output jack on my computer. Maybe I should try renaming another device?
« Reply #56 on: January 13, 2010, 12:41:01 pm »
One other thing, for media Monkey I had to download Steve Monks kernel streaming plug in. I assumed that engine 4 would be "that plug in" for xx.
« Reply #57 on: January 13, 2010, 12:43:17 pm »
Hi Leon,
I actually can't tell what ever can be the matter when all supposedly plays, but there is no sound (unless your volume slider is too low);
Please notice that the time cursor moving says nothing. The OSD Time (Unattended) does (but not all).
Can you play a track of approx. 3 minutes, wait that out (never click Stop), and post the X3PB, XX and X3 log files ?
Thank you,
Leon
oosterom@msn.com
« Reply #58 on: January 13, 2010, 01:09:51 pm »
I just did do as you asked. Now at the end of the playtime the system gives an error "Communication error with Endpoint device"
regards,
Leon
* XX-20100113-104546.log (137.36 KB - downloaded 505 times.)
* X3-20100113-130025.log (4.55 KB - downloaded 521 times.)
* X3PB-20100113-130025.log (0.58 KB - downloaded 509 times.)
« Reply #59 on: January 13, 2010, 01:29:34 pm »
Hi Leon - thank you.
A clear case of insufficient log files. And then to think I spend 30 minutes yesterday to remove all my log/debug entries ...
Allright, I'm going to do this differently;
First of all let's get rid of this stupid device selection. Secondly I'll try to find a device which makes no sound, crashes, or other stuff you encounter. Apparently this all doesn't go by itself.
MS always warned about KS not being official ...
Please note I can't work on this today and with few time the upcoming days.
Thank you all,
